Machining heads #577978
01/09/10 09:04 PM
01/09/10 09:04 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
On a j or x head could some one tell me how many thousands you have to remove to decrease your cc's by 1
Re: Machining heads [Re: flatiron] #577979
01/09/10 09:06 PM
01/09/10 09:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I think rule of thumb is .006 per 1cc,,but it can vary up or down a little.
Re: Machining heads [Re: dartman366] #577980
01/09/10 09:27 PM
01/09/10 09:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
340/360heads = .0048 cut per cc. course you will have the low of diminishing returns. Also for every .010 off the face .0095 will have to come off the intake side to match the intake surfaces.
Re: Machining heads [Re: MoparforLife] #577981
01/10/10 11:43 AM
01/10/10 11:43 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
The .0095 is machined of the bottom of the intake?
Re: Machining heads [Re: flatiron] #577982
01/10/10 11:51 AM
01/10/10 11:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no off the intake side of the head .
Re: Machining heads [Re: flatiron] #577983
01/10/10 05:22 PM
01/10/10 05:22 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Am I doing the math right?
If .080 is cut, it takes 16.66 cc out of the chamber. Correct?
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Machining heads [Re: fasteddie] #577984
01/10/10 06:55 PM
01/10/10 06:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
you got the right idea BUT its not a linear thing,
as you get down into the chamber the chamber gets
smaller... the best way to do it is to put X amount
of cc's into a level head then you know where you
need to go to
