I have a Carter 'Street Super' mechanical fuel pump. It advertised as putting out 5.5 to 7.5 PSI and 120GPH. This on a street/strip 470 with a QFT-850PV carb.
Should I run a fuel pressure regulator with this pump? I can see the fuel level thru the sight glass, and it stays at the bottom of the sight at idle, which is where I put it. If the pump was putting out too much pressure for the carb, wouldn't the fuel level in the bowl climb? Also can too much pressure affect the AFR if the fuel level stays in the right point? Since the bowl is vented, it seems too much pressure couldn't do any harm unless it was able to overfill the fuel bowl.
I recently had the car on a chassis dyno, and it was pig rich at low rpm (AFR=11.5) and some load (2000RPM and 12" of vacuum, it idles around 13", and pulls about 17" at 2000RPM and light load), but the AFR did funny things under WOT. It starts in the high 11.x/low 12.x then goes leaner than 12.8 (up to about 13.5) as it approached peak torque (4200-4400) and then started dropping back towards 12.8 beyond peak torque. I wasn't able to do a full pull on the dyno due to some equipment problems the dyno shop was having and don't know what happens past about 4700.
I don't have a fuel pressure gauge on the car yet, and will be adding one. I'm wondering whether I should add a regulator while I'm at it. It seems there may be some sort of fuel delivery problem, and I agree I need to check the FP to rule that out.
Thanks for your thoughts!
