Gear Vendors Overdrive
#577631
01/09/10 05:20 PM
01/09/10 05:20 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I use a Gear Vendors overdrive with a 4 speed and there's a small delay between hitting the switch and the overdrive engaging. Has anyone done away with the controller and operated the overdrive solenoid directly? Does it speed up the change into overdrive? The only reason I can see for the controller with a 4 speed is to switch out the overdrive when I come to a stop. It's a nice feature but I would do without it if I could speed up the shift.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
Re: Gear Vendors Overdrive
[Re: DAYCLONA]
#577633
01/10/10 07:56 AM
01/10/10 07:56 AM
Mick70RR
Birmingham, England
There's an autodrive position that's used with automatics but it's of no use with a 4 speed. I just switch the overdrive in and out when I want to. The controller switches the overdrive out when the car slows below about 15mph. It's just that there is a slight delay between operating the switch and the overdrive engaging and I was wondering if the controller was the cause. I was hoping someone had tried bypassing the controller to see if it got rid of the delay.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: Dabee]
#577635
01/10/10 01:42 PM
01/10/10 01:42 PM
Mick70RR
Birmingham, England
I know there is a small delay after the solenoid is operated while the oil pressure builds enough to engage the clutch but I thought there may be an additional delay from the controller. I find the overdrive disengages much faster than it engages too. It's not really a problem on the street, but on the drag strip it's difficult to time it so the overdrive engages at the correct rpm especially in the lower gears.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
