Dual valve springs requiring machining head? #577291
01/09/10 12:08 PM
01/09/10 12:08 PM
808CUDA Offline OP
808CUDA  Offline OP
Installing a set of dual springs (Comp) would require any special machining on a steel 915 head or do they simply swap out?
Re: Dual valve springs requiring machining head? [Re: 808CUDA] #577292
01/09/10 12:20 PM
01/09/10 12:20 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Yes,you must machine the spring seats.
Leave the gun.......take the Cannoli's....Mike
Re: Dual valve springs requiring machining head? [Re: mike s] #577293
01/09/10 12:27 PM
01/09/10 12:27 PM
808CUDA Offline OP
808CUDA  Offline OP
Thanks for the heads up! much appreciated!
Re: Dual valve springs requiring machining head? [Re: 808CUDA] #577294
01/09/10 12:33 PM
01/09/10 12:33 PM
scratchnfotraction Offline
my cam used duel springs and a damper and needed machine work
i went with a comp single with a damper so they would drop on with stock seals and heads on engine
match up the spring rates and run a big single if you want drop ons and stock seals
unless you stuck haveing to have them
I matched my lunatis with a comp spring within 10 lbs of each other
