I use their 360 stock placemnet type pans in many builds. but not sure fo the kickout in 74B body.
You do not and will not need the windage tray.
If your block is studded, you will have to do a little customizing of the pick up mounting tab. If you are using stock style bolts, then you will be able to use the bolt/stud and the pick up will be easily attached to the tab.
Doesnt matter what oil pump you use.
RIP Monte Smith
