Adjustable strut rods - A Body #577282
01/09/10 11:44 AM
01/09/10 11:44 AM
upstate NY 12839
TMBOOTS Offline OP
TMBOOTS  Offline OP
upstate NY 12839
Are they worth the extra expense?
383 dart 4-speed car - probably won't see the drag strip
Re: Adjustable strut rods - A Body [Re: TMBOOTS] #577283
01/09/10 02:08 PM
01/09/10 02:08 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
No, the only advantage on a street car would be getting more caster. If you are using modern tubular upper arms, they have more caster built into them. If you have stock upper arms you can install offset bushing at your next rebuild to get more caster.
Re: Adjustable strut rods - A Body [Re: TMBOOTS] #577284
01/09/10 02:21 PM
01/09/10 02:21 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That depends on what you want from the car. I like to go around corners as fast as possible. The after market strut rods get rid of the factory rubber bushings and replaces them with heim joints. Removing the rubber prevents the suspension geometry change that happens with hard braking. Unless you brake very hard comming into corners with modern tires you will never know the difference imo. I've seen people spend mega $$ on their suspension and brakes only to loose most all of the benefits by going with old school 15" tires.
Re: Adjustable strut rods - A Body [Re: Lefty] #577285
01/09/10 03:16 PM
01/09/10 03:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO, No, but regarding suspension geometry change under hard braking, first I don't there is that much change in a decent OEM system to begin with, second, it would only occur under very hard (max) braking, third, that hard of braking is only done when going in a straight line, fourth, any suspension geometry change is likely symetrical, fifth, not likely a big negative anyway. However the OEM type struts allow for compliance/movement, which is needed to reduce suspension geometry changes as the LCA arcs thru bumps or vertical travel as a car rolls in a turn, and that geometry change would be increased by having a strut that does not have any compliance (because the heim strut now swings thru an arc), and I suspect that geometry change during cornering effects handling far more then any change found in hard straight line braking. Using the struts to gain a lot of caster is doable but not preferred, since it begins to induce LCA bushing binding. They do have a lot of bling though. Urethane IMO is the best compromise
Re: Adjustable strut rods - A Body [Re: jcc] #577286
01/09/10 04:58 PM
01/09/10 04:58 PM
IN
ahy Offline
ahy  Offline
IN
The adjustable strut rods are a big help if running poly LCA bushings on an A. The poly bushings can be thicker than rubber and let the LCA locating pin move around which changes toe and upsets handling. The adjustable rods let you pull the LCA up snug. There are heim joint adjustable versions ($$) and straight adjustable versions. Have a look at Firm Feel's web site.
Re: Adjustable strut rods - A Body [Re: ahy] #577287
01/09/10 05:47 PM
01/09/10 05:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Or... you could just cut the poly bushing with a hacksaw. Even quicker and cheaper yet:
http://users.erols.com/mathewg/bushings.html
I did that years ago and never had and issue with alignment or pulling the LCA foward. I just run stock UCA's but I use the offset moog bushings. I can always get 4-5 degrees of positive caster depending how agressive the camber I choose to run.
Re: Adjustable strut rods - A Body [Re: jcc] #577288
01/09/10 06:19 PM
01/09/10 06:19 PM
Lefty Offline
Lefty  Offline
