Re: What 451 Stroker Rods?
[Re: CompSyn]
#577131
01/09/10 03:43 AM
01/09/10 03:43 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Used SRP pistons and 6.76 Scat rods. in my 451. IMO it's six in one and half a dozen in the other, trading rod weight for piston/pin weight... IF I was pushing the limits of pump gas in it I'd be inclined to go with the shorter rod for the shorter dwell "near TDC" and the quicker movement away from TDC to minimize chance at detonation, would it matter? maybe maybe not in theory that's how it would/should work.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#577133
01/09/10 10:30 AM
01/09/10 10:30 AM
Posts: 4,978 VA
DAMOPARS
VA
SRP pistons and 6.76 scat rods here too.
[Re: CompSyn]
#577134
01/09/10 12:12 PM
01/09/10 12:12 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Its not really a big isssue on that combo either way, but I am a firm believer in using the longer compression height piston in a street combo. Much better on a street engine for piston stability. Either combo can run just fine.
RIP Monte Smith
[Re: CompWedgeEngines]
#577135
01/09/10 04:41 PM
01/09/10 04:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I used the RB length Rod. They are more readily available in an economical H-beam design. Andy F.'s new book says that the short rod version will make slightly more low end power (???). not sure why that would be, but I'm sure Andy knows what he's talking about. Seems to me that using a shorter rod would mean a longer piston, which would negate at least some of the weight advantage the longer rod motor enjoys (???).
[Re: fourgearsavoy]
#577137
01/09/10 10:47 PM
01/09/10 10:47 PM
CompWedgeEngines
Syracuse,NY
I can vouch for the K1 rods as well. Dan (DRAM) and I were some of the first to really push the K1 parts when they first started out. Still the best bang for the buck in my opinion.
RIP Monte Smith
#577138
01/13/10 07:37 AM
01/13/10 07:37 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
To confirm, are you saying that by using the shorter 'B' rod, you get a piston with a "longer compression height" and thus a piston that may be more stable for a street engine, correct?
Not trying to stir up controversy here. It's a 50/50 toss up for me, e.g, one KB piston/stock rod combo over the other. If one combo is better suited for an iron headed, pump-gas, mostly stock build, I'd like to find out.
I guess if I have to give in to a little extra piston side loading for a lesser chance of detonation and pick up a little extra low-to-mid range power for my B-Body, the shorter 'B' rod may be a good choice for me?
[Re: CompSyn]
#577139
01/13/10 11:18 AM
01/13/10 11:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I used the same stroke in my 383 block for a 438 cu in motor--.060 over 383 block.
I went with the 440 stroke, 440 rods, and short pistons. makes for a light rotating assembly that revs quick especially if you use the floating .990 pins instead of the larger press fit pins.
I have no piston slap or rock in my motor even when it's cold. 4,000 street miles so far in the past 2 years, and all seems to be going well.
**Photobucket sucks**
[Re: CompSyn]
#577140
01/13/10 11:28 AM
01/13/10 11:28 AM
RapidRobert
My 451 coming together w KB 280's (1.327 CH) and RB rods. I am more concerned w not increasing the side loading than piston weight but I dont want piston rock to shorten my longevity somewhere down the line. I'm assuming 1.327 is not in the danger zone???
