Re: Shear plate question
[Re: nz383man]
#576919
01/09/10 12:47 AM
01/09/10 12:47 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Larger bore is on the "top",.....meaning the larger bore of the venturi sees flow first, as the flow passes thru the larger bore first, the smaller secondary, or tapered section of the bore is designed to contain/control the reversion pulse,....On the topic of AR control (Anti-Reversion)there was at one time an interest also in AR exhaust headers (anti-reversion), that had a reversion cone welded into the exhaust flange that bolted onto the exhaust port section of the head,....AR carb plates, manifolds with AR port designs, AR headers, while offering benefits, are best suited for engines that operate at continous RPM "bands" for extended time
[Re: DAYCLONA]
#576920
01/09/10 01:58 AM
01/09/10 01:58 AM
Posts: 520 New Zealand
nz383man
New Zealand
Thanks DAYCLONA, that is the way I thought they would work buy I didn't want to take it for granted. On the AR header thing David Vizard has positive things to say in his books about it including gains/losses from mismatching ports/manifolds & relationships between AR & balance pipes etc, interesting reading. I run a factory appearing 383 in my Barracuda & intend building AR fittings into my headpipes in the next couple of weeks. (materials purchased today) As for the shear plate it will probably be more of a winter (downunder) project as I want to incorporate the shearplate system into an insulating plate rather than an alloy one.
[Re: nz383man]
#576922
01/12/10 07:06 PM
01/12/10 07:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Kevin I assume your running cast iron exhaust manifolds?,...that's possibly the reason your putting the AR cones in the headpipes,....which is ok,...but if you had the time, a sheetmetal gasket .060 (1.5mm) could be fashioned to portmatch the exhaust profile of the head, and individual AR cones could be welded to it to support their placement in the exhaust manifold passages,....IIRC from my studies of AR and the exhaust port head exit, the closer you can get the AR cone to it, the better the benefits of AR scavenging of the cylinder,....also if your running a straight thru muffler design, an AR cone in the inlet, will benefit the scavenging pluse in the main headpipe,.....but when it comes to the actual size/orifice dia, length/angle of the AR cones, best to consult some flow tables/charts that are in close comparison to your engines perimeters, plus your intended operation range (RPMs)
Mike
[Re: DAYCLONA]
#576923
01/13/10 01:23 AM
01/13/10 01:23 AM
nz383man
New Zealand
Thanks for the positive comments guys, I've taken your comments/ideas on board. It's great to get positive comments especially from a couple of big players, I get a bit board with some of the negative sh!t from people who have never done anything constructive in their life.
[Re: nz383man]
#576924
01/13/10 10:44 AM
01/13/10 10:44 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I get a bit board with some of the negative [Edited by Moparts - Family Friendly Site - Keep it clean] from people who have never done anything constructive in their life.
