Adding a rear sway bar to 64 Fury #576495
01/08/10 08:49 AM
01/08/10 08:49 AM
Blanchard, OK
Real-Fury Offline OP
Blanchard, OK
I know this has been discussed on the forum before and I tried doing a search of the archives but came up with nothing.
Has anyone added a rear sway bar to a 64 Fury or similar B body? Is there a benefit to adding a rear bar that can be felt?
A front sway bar has already been installed on this car but nothing on the rear so I was thinking of adding it. Is this a bolt on installation or does it require cutting and welding?
Thks,
Butch
Re: Adding a rear sway bar to 64 Fury [Re: Real-Fury] #576496
01/08/10 11:12 AM
01/08/10 11:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I used the Moparts search function: https://board.moparts.org/ubbthreads/search.php?Cat=0
In the Keyword search terms I typed "rear sway bar" and searched 6 monthes back and highlighted the Question and Answer section:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Adding a rear sway bar to 64 Fury [Re: autoxcuda] #576497
01/08/10 02:20 PM
01/08/10 02:20 PM
Blanchard, OK
Blanchard, OK
Fantastic Information Autoxcuda! This is exactly what I needed. Complete story on sway bars and installation. It looks to be a much easier installation than I imagined.
Thank you!
Butch
