Re: 71 Scamp with Magnum 360 ???
[Re: moparguy1967]
#576316
01/08/10 06:00 PM
01/08/10 06:00 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
You need more motor and carb for those gears, cam and heads are a good place to start
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: MagnumDartSport]
#576321
01/08/10 09:56 PM
01/08/10 09:56 PM
Posts: 1,880 USA
Ron Silva
USA
Since you have the airgap and a 650 carb I would say 3.91 would be ideal. Maybe even 3.73's would be better if that tire is 26" tall.
But with changes to the cam and heads I might leave the gear alone for now. Especially if you don't mind it and if it happens to dead hook at the track. You might try going to a taller tire after these wear out, (if it will fit) if you are inclined to gear it taller after the changes.
If you keep that gear I might try a Mopar M-1 open plenum manifold and a 750.
SRT DEMON ONE SEAT
