1968 440 Block Stampings.....numbers posted
#575730
01/07/10 12:28 PM
01/07/10 12:28 PM
Posts: 735 New York
R/T1968R/T
New York
Picked up a 68 HP block cast in late 67. I noticed the normal production number on the pan rail.....PT440..... Upon further inspection I found what appears to be a vin number on the block near the bell housing area.I have two other 68 blocks that dont have this. Is this normal? I will post pictures later.
Re: 1968 440 Block Stampings
[Re: 5wndwcpe]
#575733
01/07/10 08:33 PM
01/07/10 08:33 PM
Posts: 4,872 connecticut
pnypwr
connecticut
68 are hit or miss, some were stamped some werent, on the bell housing flange drivers side usually. Ive also seen 68s that have the trannys stamped and the blocks not stamped...guess it was the line guys felt like doing that day!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: monacoman]
#575735
01/07/10 09:13 PM
01/07/10 09:13 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
Is there a website where you can decode this number? Thanks
yes , you are on it .
it will be 8 digits long, the year , 8 , a letter for the plant the car was built at and the last 6 digits of the cars VIN .
[Re: R/T1968R/T]
#575739
01/08/10 11:11 PM
01/08/10 11:11 PM
JohnRR
U.S.S.A.
and this......
This is the partial VIN from the car that motor was installed in
[Re: 6bblgt]
#575742
01/08/10 11:20 PM
01/08/10 11:20 PM
JohnRR
U.S.S.A.
1968 440 HP What info is on the top pad?
PT - Trenton engine plant 440 - ?? S - "special" 2285 - October 30, 1967 machine date 2428 - unit number
Engine is from XS29L8B186498, built first week of November 1967 in Hamtramck, MI.
I assume chargers were only B body built at Hamtramak in 68 ?
[Re: 6bblgt]
#575743
01/09/10 03:57 PM
01/09/10 03:57 PM
Posts: 735 New York
R/T1968R/T
New York
Here is the pad.
[Re: Captain Flapjack]
#575745
01/09/10 06:05 PM
01/09/10 06:05 PM
JohnRR
U.S.S.A.
dont those block vin numbers look like the same font as the body stamp numbers?????
The engine VIN would be stamped at the final essembly plant so I'm not surprised by it .
[Re: MODODMO]
#575747
06/01/14 05:02 PM
06/01/14 05:02 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
8B383218
The "B" in the partial VIN identifies the Hamtramck (Dodge Main) assembly plant.....with 440 power, Hamtrack built Coronets and Chargers in '68.
PT440S24812718
PT= Plant Trenton 440= Displacement S= Special Engine 2481= Build date May 13, 1968 2718= Sequence number, the 2718th built that day.
[Re: John_Kunkel]
#575748
06/01/14 05:25 PM
06/01/14 05:25 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
8B383218
John, Coronets were assembled at Lynch Road, Stl and LA in 68. The engine must be from a Chrger R/T.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
