Re: Max compression ratio?
[Re: mopartruckguy]
#575495
01/07/10 12:43 AM
01/07/10 12:43 AM
Posts: 2 Rocklin, CA
Bret Ingram
Rocklin, CA
Hello everyone! I am back on Moparts! Been a while.
We have a '86 W-150 4x4, 4-sp, with a 360 factory Q-jet 4bbl that my brother and I re-built and has been squared, decked, bored .030 over with torque plates, aligned honed, shot-peened, balanced, and blue-printed, etc. It has a "true" 8.89CR with a Scott Brown custom cam that measures .201/.206 @ 050 with .432 lift on both the intake and exhaust on a 113 centerline (I think)installed and degreed "straight-up"! We put 308 heads on it, port-matched them and ported them mildly. Timing is set a factory specs of 16 degrees minus the advance. I can tell you under medium to heavy acceration, when towing it pings on 87 octane. 92 octane works fine. I know this engine begs for a cam with more duration but this is a smog engine and passes just fine. The torque is very strong, especially with 32" tires and stock 3.55 gears. If you don't have to worry about smogging it, go for 9.5 CR in a light car and gears with much more overlap on the cam and you'll be fine on 92 octane gas.
Good luck!
Bret
[Re: mopartruckguy]
#575500
01/07/10 08:46 AM
01/07/10 08:46 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
if you are willing to suffer a loss of torque and horsepower at full throttle, you can retard the ignition timing to prevent detonation and (possibly) decrease the coolant temperature and get up to a 6% fuel economy increase:
