Indy Cover and Roller thrust button setup..PART II #575189
01/06/10 06:45 PM
01/06/10 06:45 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
I just figured out if the end play isnt correct, it;s not going to be easy to adjust the endplay with this setup. I was told by Mancini that this Diamond Racing Products roller thrust button setup is designed to work with the Cast Indy Cover...
I was thinking they make a shim kit for this, but what if I dont have enough to begin with...
Anyone run this setup?
Re: Indy Cover and Roller thrust button setup [Re: Bob_Coomer] #575190
01/06/10 06:57 PM
01/06/10 06:57 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I got away from the torrington style and use the nylon button type. I have seen the torrington bearings come apart and let the needle bearings fall into the pan and find their way through the pick-up strainer and wreck the oil pump and associated parts! My $.02. Comp Cams makes the nylon type and probably other suppliers are out there too.
If you like drag racing, support your local track.
Re: Indy Cover and Roller thrust button setup [Re: CHAPPER] #575191
01/06/10 07:13 PM
01/06/10 07:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We just jig it up in the mill and cut a few thousands of at a time till we get our desired clearence.
Re: Indy Cover and Roller thrust button setup [Re: B G Racing] #575192
01/06/10 08:02 PM
01/06/10 08:02 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I took a ton out of mine on the mill and it still wasn't close so i ended up just making a aluminum bushing instead of that roller bearing. Another thing is that bearing isn't real friendly with 3/8ths bolts either.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Indy Cover and Roller thrust button setup [Re: bigtimeauto] #575193
01/06/10 08:46 PM
01/06/10 08:46 PM
UK
602heavy Offline
602heavy  Offline
UK
Just drilled a hole through the front cover & installed an adjustable bolt on to the cam button.
Re: Indy Cover and Roller thrust button setup [Re: 602heavy] #575194
01/07/10 11:35 PM
01/07/10 11:35 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
i chucked mine up in the vise under my drill press and put a sanding disc from my side grinder in and slowly milled off enough to have the proper clearence..took about 15-20 minutes and fits fine...
Re: Indy Cover and Roller thrust button setup..PART II [Re: Bob_Coomer] #575195
01/10/10 11:27 PM
01/10/10 11:27 PM
Rock Springs
Rock Springs
Well..
This setup will NOT work with the Cloyes True Roller timing set..This is the timing set that has the torrington bearing on the back side between the cam gear against the block....
I would need to take almost 3/8" off to make this work.. I was going to just omitt the torrington bearing, but the way the cam gear is made, it has a register ring that locates the torrington bearing..No way that just the ring cold ride against the block.
So...I ordered up a Comp Cam Nylon Thrust button. I figured that the torrington bearing will help save the block thrust area.. The nylon will wear, and the timing chain cover shouldnt wear any, if it does its replaceable. I figured the block side needed the bearing over the timing cover..
So just a heads up with anyone looking at this setup. It wont work. Im pretty sure the particular timing set I have with the torrington bearing is a good bit wider than a standard non bearing cam set..
So I will return the roller thrust bearing, and just use some header bolts to attach the cam gear. Those 3/8 header bolts with there little 3/8 reduced socket heads really works nice attaching the cam gear to the cam.
Re: Indy Cover and Roller thrust button setup..PART II [Re: Bob_Coomer] #575196
01/10/10 11:54 PM
01/10/10 11:54 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I have used several of these covers and the only setup I have found to work is the nylon button and button head bolts.When I tried the header bolts they hit the cover also.By the time I grind the button to about half its original thickness and grind three flats on the side to clear the button head bolts its not much left of it, but it works.
Re: Indy Cover and Roller thrust button setup..PART II [Re: Bob_Coomer] #575197
01/11/10 05:58 AM
01/11/10 05:58 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I have just always used indys timing chain and button with the indy cover
Re: Indy Cover and Roller thrust button setup..PART II [Re: Bob_Coomer] #575198
01/11/10 11:49 AM
01/11/10 11:49 AM
AndyF Offline
AndyF  Offline
I make a button that fits my cover.
Re: Indy Cover and Roller thrust button setup..PART II [Re: AndyF] #575199
01/11/10 11:51 AM
01/11/10 11:51 AM
AndyF Offline
AndyF  Offline
I also provide an extra center section with an access slot so the end play can be directly measured.
