u joint strength #575172
01/06/10 06:40 PM
01/06/10 06:40 PM
West Tennessee
rbstroker Offline OP
West Tennessee
I am trying to find a chart telling what the strength of the various Mopar u joints might be (7260, 7290, 1330). I currently have a 7260 rear joint and a ball and trunnion front joint in my early bracket car. Not too worried about the B&T but the 7260 gives me something to think about since I am upgrading to bigger tires.
This is the land of the free because of the brave
Re: u joint strength [Re: rbstroker] #575173
01/06/10 07:23 PM
01/06/10 07:23 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
How fast is the car? I have seen plenty of people running low 10's with 7260's with trans brakes.
Re: u joint strength [Re: slantzilla] #575174
01/07/10 11:30 AM
01/07/10 11:30 AM
West Tennessee
West Tennessee
7.99 1/8 mile is the target this year.
Re: u joint strength [Re: rbstroker] #575175
01/08/10 12:46 PM
01/08/10 12:46 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Use a solid 7260 race u-joint if you're not already using one.
The guy who built my custom driveshaft used them for my old street driven built 340-4spd Duster since my HP was way more than stock.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: u joint strength [Re: MY340] #575176
01/08/10 08:07 PM
01/08/10 08:07 PM
Locomotion Offline
Locomotion  Offline
I've been using Spicer solid 7260 u-joints in my car since 1999 and never had a u-joint related problem. However, I did find that the OEM rear end yokes can start to spread and let the u-joint pound themselves out. I went to a billet yoke and no issues for years! I've run 11.31 @ 115 with 1.47 60' times with the wheeels up....weighing 3,540+ lbs! I'm very happy with my 7260 joints.
Re: u joint strength [Re: Locomotion] #575177
01/08/10 08:12 PM
01/08/10 08:12 PM
Myron do you have a # handy for the 7260 solid Spicer one? I never thought about the solid/hollow difference until I read this (& the other) thread but I'm a quick study and a believer now.
Re: u joint strength [Re: rbstroker] #575178
01/08/10 09:27 PM
01/08/10 09:27 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My Valiant has been 7:40's with standard NAPA 7260 joints with grease zerks in the caps.
Re: u joint strength [Re: slantzilla] #575179
01/08/10 10:14 PM
01/08/10 10:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
My charger did 7.0 1/8th mile times off a T brake W/ a 7260 front joint and a 7260/7290 conversion joint in the rear
Solid joints of course
Re: u joint strength [Re: WILD BILL] #575180
01/08/10 10:26 PM
01/08/10 10:26 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
To make the U-Joint a little more reliable, if it is greasable, place the grease fitting so it is getting pushed together by the driveshaft turning, not trying to pull the fitting apart. a little off topic, just my...
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: u joint strength [Re: jrlegacy23] #575181
01/09/10 11:33 AM
01/09/10 11:33 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
a solid ujoint is great for a race car that sees 100 miles a year but for a street car that sees thousands of miles needs to be greased periodically. the zerk makes that possible with ease. ive run the hollows on mine and never broke the cross shaft. i have seen lack of greease destroy rollers and caps though.
so i would think that if you were running a 11 or 12 second street car that sees track time, you need the greaseable fittings unless you want to pull the ujoints out every year to grease them
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: u joint strength [Re: aarcuda] #575182
01/09/10 11:48 AM
01/09/10 11:48 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Hey guys, if you go to some of the major driveshaft maker sites, there is a lot of good information available on this subject! One of the is www.drivelineshop.com Go to their specsheets section and it tells you the torque ratings of the commonly available u-joints. it says 7260 rated for 400 ft. lbs. continuous torque, 800 ft. lbs. short duration torque, and 1600 ft. lbs. to failure. 7290 #'s are 550, 1000, and 1875.
Dennys driveshaft site also has good relevant info under FAQ's. Lee.
Re: u joint strength [Re: RapidRobert] #575183
01/09/10 01:20 PM
01/09/10 01:20 PM
Locomotion Offline
Locomotion  Offline
Sorry, I don't have the number handy. My driveline guy put them in years ago and I never got around to getting spares. The spares I do have are Brute Force, but he said Spicer is a better joint.
Re: u joint strength [Re: Locomotion] #575184
01/09/10 01:25 PM
01/09/10 01:25 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
great, now you all have me thinking I need a new driveshaft with bigger ujoints, yokes etc...
Re: u joint strength [Re: aarcuda] #575185
01/09/10 01:33 PM
01/09/10 01:33 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And another variable to add.... ...I just had a shaft made up this week for a road runner I'm working on...There's a few different syles of solid joints...Some are heat treated and some are'nt...FWIW...I used the spicer solids in past years...This time I went with the brute force heat treated..The shop claimed they were the best with a bigger diameter at the cap than the others and use them in all the serious drag pieces they make..
Re: u joint strength [Re: aarcuda] #575186
01/09/10 01:35 PM
01/09/10 01:35 PM
great, now you all have me thinking a need a new driveshaft with bigger ujoints, yokes etc.
We dont have any of our own money to spend...
Re: u joint strength [Re: RapidRobert] #575187
01/09/10 01:50 PM
01/09/10 01:50 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
7260 Spicer solid u-joint # 5-789X. I've been using these on my bracket car for years leaving on a trans brake.
Re: u joint strength [Re: 360DOUG] #575188
01/09/10 04:52 PM
01/09/10 04:52 PM
West Tennessee
West Tennessee
Where is the best place to get either the spicer or the Brute Force u-joints?
