Re: how to increase oil press in smallblock
[Re: w2dak394]
#574553
01/06/10 12:32 AM
01/06/10 12:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
found out today the high press spring not avaliable. what to do to pump to increase pressure?
Put a washer behind the relief spring or heavier weight oil
[Re: w2dak394]
#574554
01/06/10 01:32 AM
01/06/10 01:32 AM
Posts: 4,209 New York
polyspheric
New York
How much pressure do you have now? With what oil? How much do you think you need, and why?
Boffin Emeritus
[Re: w2dak394]
#574556
01/06/10 05:39 AM
01/06/10 05:39 AM
Posts: 7,506 Az
Crizila
Az
Unless you are building it real loose, you shouldn't have a problem meeting those pressures with a stock high volume melling pump. That's what I get out of mine.
Fastest 300
[Re: DavidDean]
#574558
01/06/10 12:13 PM
01/06/10 12:13 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The HV pump has the higher pressure relief. The std pumps need to shim or replace the spring... And I got one from Manicini about a month ago.
[Re: DavidDean]
#574559
01/06/10 12:15 PM
01/06/10 12:15 PM
Quicktree
I just ordered a high pressure spring from Mancini today
why do you need it? a stock pump will get the job done unless you have a problem elsewhere
[Re: polyspheric]
#574560
01/06/10 12:30 PM
01/06/10 12:30 PM
Posts: 3,695 nc
emarine01
nc
[Re: DavidDean]
#574562
01/06/10 08:16 PM
01/06/10 08:16 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I run a stock pump and have almost 80 psi cold at idle and it carrys 45-50 idle and 80 down track hot all day long.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
