Who makes the best underhood insulation pad clips? #574314
01/05/10 10:02 PM
01/05/10 10:02 PM
Arizona
az426john Offline OP
Arizona
I mean one's that bend and actually spring back not just bend and deform so you have to open them up and then they break.
Re: Who makes the best underhood insulation pad clips? [Re: az426john] #574315
01/06/10 08:32 AM
01/06/10 08:32 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
I've had nice results with Auveco clips, the plastic ones anyway.
Re: Who makes the best underhood insulation pad clips? [Re: az426john] #574316
01/06/10 10:04 AM
01/06/10 10:04 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used a set of the metal ones on my former challenger, Most broke before then snapped back into place( I have no idea where I bought them )
I ended up using the plastic ones as used on 1972 and up cars
Re: Who makes the best underhood insulation pad clips? [Re: az426john] #574317
01/06/10 11:13 AM
01/06/10 11:13 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
If you have a NAPA nearby, they have a fastener book about the size and in the format of an 8 1/2 x 11 calendar. It has the fastener picture and sometimes even the OEM part number. Excellent reference. Maybe they have that type or similiar clip. worth a try.
Common sense is a flower that does not grow in everybody's garden
Re: Who makes the best underhood insulation pad clips? [Re: Ron_M] #574318
01/06/10 01:38 PM
01/06/10 01:38 PM
warmpancakes Offline
mmm.... maple syrup.....
can you post a pic of the ones you need?
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
Re: Who makes the best underhood insulation pad clips? [Re: warmpancakes] #574319
01/07/10 11:25 AM
01/07/10 11:25 AM
Arizona
Arizona
Here are a couple of photo's
They are 1-3/4" long and 13/16" wide.
The one's I have that are painted semi-gloss black work better than the one's I have that are phosphate coated.
Re: Who makes the best underhood insulation pad clips? [Re: az426john] #574320
01/07/10 11:26 AM
01/07/10 11:26 AM
Arizona
Arizona
Photo 2
