Re: Wheelie Bar questions
[Re: Plumcrazyracing]
#573779
01/05/10 04:42 PM
01/05/10 04:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just built and installed bars (spring loaded) on a 71 Duster. Overal length is 64 inches. Caltracs, split mono leaf, rancho 5 way, transbrake, 3330 race weight, 10 oh to 10.20
I would like to know where to set the wheel height on the bars (at least a general idea). I have been told that i need almost 12" of height. Any truth to this?
Thanks!
I set my about 4" to the C/L of the wheel... but I run a 4-link... your going to get more wind up so I would start about 5" and play with it from there... you need to remember that you also have the spring thats on them... lift the bars all the way up to see where they would be locked up
#573784
01/05/10 10:24 PM
01/05/10 10:24 PM
Posts: 581 Hamiltucky
RBDuster
Hamiltucky
RBDuster: How long are your bars? I assume you run Caltracs? Pics?
Bars are 60" and spring loaded. No Caltracs just ladderbars
[Re: ITSDUSTA416]
#573785
01/05/10 10:26 PM
01/05/10 10:26 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
4 - 6" as per Comp Eng. details .I`m starting there . Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: curt jr]
#573786
01/05/10 11:10 PM
01/05/10 11:10 PM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
According to most wheelie bar charts that I've seen at the shop(BGR) and when we set them its usually between 3" to 6" on a ladder bar and 4 link car. On a spring car or Cal-Trac setup we generally set them no more than 8"
I tried 4 to 5 inches, and they hit so hard it unloaded the tires. I will try to get them between 8 and 10 to start this year. I watched a video of a camaro on yellowbullet and you couldn't beleive how much the rear rotates with caltracs and split mono leafs
[Re: 4404dart]
#573787
01/05/10 11:49 PM
01/05/10 11:49 PM
Posts: 20,863 A collage of whims
topside
A collage of whims
Mine are set at 10"L/10.5"R, measured at the center, car's happy with that. Car likes to hike its LF a bit more than the RF; probably under-caged, but it's a vintage car so I'm not changing that. Modified SS springs, footbrake, 5800stall. No snubber. 13x31s, usually @ 7.5PSI cold. It'll carry the front tires out a good way, as much as 100 feet, on a good track, sits down very politely. Just knocks the shoe polish off about 15% or so of the bar's wheels. Goes straight as a string. 368" SB Duster/904/5.38 Dana, about 3000lbs, my weight about 160. 100lbs ballast. Low 10s with a 750 carb, should go 10.0 with the 1050. (If that info helps.)
Post deleted by Defbob
[Re: MR_P_BODY]
#573789
01/06/10 12:36 AM
01/06/10 12:36 AM
[Re: 9 Sec Phill]
#573792
01/06/10 01:31 AM
01/06/10 01:31 AM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Well I will be the stick in the mud. BUt as you can see it will depend on the car. There is no magic answer. A caltrac car making 500hp with a SB will need something different thsn the saem car with a 1000hp BB. Pick a hieght and get out and run it, video is an excellent tool when tuning things like wheelie bar height.
[Re: Al_Alguire]
#573793
01/06/10 01:55 AM
01/06/10 01:55 AM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
I agree with Al, it all depends with how quickly it pitch rotates. Some if there too high the momentum will unload the tires when the bars hit. On 9 sec Phils IMO when he had them low it wasn't allowing the chassis to transfer weight and spinning but not from unloading.
[Re: TS3303]
#573794
01/06/10 02:38 AM
01/06/10 02:38 AM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
Thank you for the info guys. Forgive me for asking, but could someone explain "pitch rotate". For anyone that is interested, i am posting a link of video of the cars' launch. Any comments are welcome. My car is videoed right at the 16 second mark. Purple 71 duster in the left lane. http://www.youtube.com/watch?v=gnzDm3PHGxY
