mounting slicks(no FRED its not what you think) #573663
01/05/10 10:29 AM
01/05/10 10:29 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this is my first set of new slicks,i finally got a car that has enough power(just barly) that used broke down old tires dont work that good.ive been told to treat the inside,some say with soap and some say baby powder and ive got a couple other suggestions of some weird stuff,anywho what do you guys do to yours? goodyear 32-14-15 d-5
Re: mounting slicks(no FRED its not what you think) [Re: bonefish] #573664
01/05/10 10:56 AM
01/05/10 10:56 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Soap is for tubeless, to help seal. Baby powder is for tubes, to help the tube position correctly and not get pinched during inflation.
Re: mounting slicks(no FRED its not what you think) [Re: moparguy7074] #573665
01/05/10 12:00 PM
01/05/10 12:00 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ive always used soap for a lube to mount the tyres but how is it applied as a sealant?do you just paint it on full strenth or as a dilluted mixture?do you cover the entire inside?
Re: mounting slicks(no FRED its not what you think) [Re: bonefish] #573666
01/05/10 12:09 PM
01/05/10 12:09 PM
sg66mopar Offline
sg66mopar  Offline
Are you trying to keep the tires from leaking? That's what the soap is for. My tire guy used to coat the inside (lightly) with Dawn dish soap. He says the new tires have a better carcass and they don't need the soap any more. I went through 3 sets of Goodyears last year with no coating of any kind inside and had virtually no leaks.
When I put my car in the shop for it's winter freshen up the first week of November I put the slicks at 11 pounds and when I checked them a couple days before Christmas they were still at 10.
Re: mounting slicks(no FRED its not what you think) [Re: sg66mopar] #573667
01/05/10 12:18 PM
01/05/10 12:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I wiped down the inside of mine with green slime from the local auto parts store. haven't leaked a bit yet.
Re: mounting slicks(no FRED its not what you think) [Re: sg66mopar] #573668
01/05/10 12:21 PM
01/05/10 12:21 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
mabey im worrin over nuthin,my old cracked side wall 5 yr old tyres hold air for 6 mo. at a time and even then there not flat just need to be pumped up a little.i paid alot for these tyres(to me anyways) and just want to do it right.
Re: mounting slicks(no FRED its not what you think) [Re: Quicktree] #573669
01/05/10 12:22 PM
01/05/10 12:22 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
as mentioned if you are going tubeless apply a coat of soap to inside of tire before mounting.
Re: mounting slicks(no FRED its not what you think) [Re: bonefish] #573670
01/05/10 12:24 PM
01/05/10 12:24 PM
Rudolph, Ohio
Rudolph, Ohio
Full strength.
Re: mounting slicks(no FRED its not what you think) [Re: bonefish] #573671
01/05/10 01:14 PM
01/05/10 01:14 PM
Az
Crizila Offline
Crizila  Offline
Az
The soap has no sealing qualitys. It's used on the tire bead area to make sure the bead fully seats on the rim ( snaps up against the rim edge all the way around when aired up ). When mounting slicks, I would use it spairingly - just a small amount ( cap full ) in a bucket of water to keep tire / wheel slipage possibilities to a minumum. Most tubes ( if you are using them ) come powdered, but some additional dusting wouldn't hurt. Most tire shops use a product called "Ru-glide" as a mounting lubricant, but don't know the properties of the stuff or how well it would work in slick mounting applications. It is slick as snot!
Fastest 300
