Re: Weiand 8007 vs Eddy Performer
[Re: HerboldRacing]
#572774
01/04/10 08:36 PM
01/04/10 08:36 PM
moparpollack
Lil Herman
Lil Herman
85086
Why not a M1 it's set up for a spreadbore?
[Re: moparpollack]
#572775
01/04/10 08:41 PM
01/04/10 08:41 PM
Posts: 127 Phoenix, Arizona
HerboldRacing
Phoenix, Arizona
I probably should have mentioned I want a dual plane intake. All the spread bore M1's I could find are single plane.
[Re: HerboldRacing]
#572776
01/04/10 09:05 PM
01/04/10 09:05 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Weiand 8007 for sure. Make sure you gasket match the runner exits. The roof necks down to 318 size for the last inch or so. That needs to be corrected.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#572777
01/04/10 10:36 PM
01/04/10 10:36 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
on a 408, I'd look for a used LD340 to modify, or use the M1 single plane. the bigger motor will appreciate the increased plenum volume of a single plane, and the displacement will offset any torque loss due to the single plane.
[Re: patrick]
#572778
01/04/10 10:43 PM
01/04/10 10:43 PM
Posts: 15,487 Florida
scratchnfotraction
mod a LD340 to take a spredbore carb well worth the time and effort,IMHO LD340 is right on par with the eddy airgap rpm intake even though its 35-40 yrs old its duel plane also
