Balancer Question #572689
01/04/10 07:19 PM
01/04/10 07:19 PM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
My machine shop is internally balancing my 4.15 stroke, 400 Based stroker motor. He asked me today that before he started, which balancer am I using. He said if I was using an ATI super damper it wouldn't matter.
I have not gotten one yet, but does it matter which one I use as long as I use a neutral balanced damper? I know ATI is great quality, but can't I go with a Summit SFI internal balance and not have to worry about the balance being messed up?
Any recommendations?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Balancer Question [Re: jrlegacy23] #572690
01/04/10 07:54 PM
01/04/10 07:54 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I have great luck with a Fluid Dampner,I was running a 572 hemi on alcohol with a 500 shot of NX,it always worked great..Also they had a recall on a balancer I had for 3 years and they fixed it for free you got to love that.
Re: Balancer Question [Re: Hemiruss] #572691
01/04/10 07:57 PM
01/04/10 07:57 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Probably not relevant but when I had my 67 440 balanced I had to bring them the stock balancer for them to balance the engine..
Re: Balancer Question [Re: minivan] #572692
01/04/10 10:54 PM
01/04/10 10:54 PM
Cooperstown, NY
Cooperstown, NY
Is an ATI more neutrally balanced than any other dampner
Re: Balancer Question [Re: jrlegacy23] #572693
01/08/10 09:40 PM
01/08/10 09:40 PM
Cooperstown, NY
Cooperstown, NY
Anyone know?
Re: Balancer Question [Re: jrlegacy23] #572694
01/09/10 02:36 AM
01/09/10 02:36 AM
MNobody Offline
MNobody  Offline
Maybe contact ATI and ask them? might be quicker.
Re: Balancer Question [Re: MNobody] #572695
01/09/10 05:46 AM
01/09/10 05:46 AM
Cooperstown, NY
Cooperstown, NY
I may have to, I just wasn't really in too much of a hurry... I just figured there had to be some machine shop guys on here that have hands on experiences with stuff like this
Re: Balancer Question [Re: jrlegacy23] #572696
01/09/10 06:20 PM
01/09/10 06:20 PM
MNobody Offline
MNobody  Offline
Give it some time they're out there.
Re: Balancer Question [Re: jrlegacy23] #572697
01/09/10 08:48 PM
01/09/10 08:48 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
ATI's come pre-balanced from the factory.
Re: Balancer Question [Re: 64Post] #572698
01/09/10 10:00 PM
01/09/10 10:00 PM
Cooperstown, NY
Cooperstown, NY
My question is, does an ATI come better neutral balanced than any other neutral balanced balancer? If you are internally balancing an engine, do you need the balancer? Or can I just buy any neutral Balanced damper after it was balanced?
Re: Balancer Question [Re: jrlegacy23] #572699
01/10/10 03:00 AM
01/10/10 03:00 AM
MNobody Offline
MNobody  Offline
Neutral balance is neutral balance, how close they balance it is another thing. I guess it depends on who does it and unless someone has done a comparison who knows. I'm assuming any good neutral balanced one will work, it's getting balanced with the rotating assembly.
Re: Balancer Question [Re: jrlegacy23] #572700
01/10/10 03:34 AM
01/10/10 03:34 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I can't speak to that.
There are 2 and 3 ring ATI balancers available, with the 3 ring being better. There are additional costs in running the 3 ring, but they're somewhat offset by the $70 difference in price.
The 3 ring is thicker, and you'll need a longer damper bolt, special crank pulley, longer pulley bolts, and a shorter belt if you want to run a stock 3 pulley type set up. I recently worked out all of the parts required to make it simple. PM me if you decide to go that way.
Re: Balancer Question [Re: 64Post] #572701
01/10/10 06:04 AM
01/10/10 06:04 AM
Cooperstown, NY
Cooperstown, NY
Thanks guys, for the help.
64Post, I am not sure which way I am going with the pulleys yet, but I will PM when I do.
Re: Balancer Question [Re: jrlegacy23] #572702
01/10/10 11:20 AM
01/10/10 11:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Neutral balance is neutral balance , some are closer than others ... ??? ... , your shop is RECOMMENDING to you to go with the ATI , that's all, you seem to be reading into it way too much. If you want to use something else then I would tell that to the shop before you get it and have the shop spin it and they can correct it as/if necessary. I have a BHJ and had it spun , it was out a little , drill a hole , fixed .
