who makes reproduction wiring harness besides painless? #572000
01/04/10 03:23 AM
01/04/10 03:23 AM
pa
lboggie Offline OP
lboggie  Offline OP
pa
Hello, who makes wiring harness complete or what is available for the a body dart enging compartment or inside the car? Is there anyone beside painless wiring? Simple plug in ? Thanks.
Re: who makes reproduction wiring harness besides painless? [Re: lboggie] #572001
01/04/10 03:48 AM
01/04/10 03:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Painless makes a Reproduction wire harness for a Mopar? If they do I've never heard of it, just custom Hot Rod stuff AFAIK????
The best reproduction harnesses are made by M&H Wiring, they are sold exclusively through Year One. 1-800-YearOne
Re: who makes reproduction wiring harness besides painless? [Re: ScottSmith_Harms] #572002
01/04/10 04:44 AM
01/04/10 04:44 AM
You can also check with Bill & Rose Evans.
http://evanswiring.tripod.com/
Re: who makes reproduction wiring harness besides painless? [Re: lboggie] #572003
01/04/10 08:11 AM
01/04/10 08:11 AM
ne
broncobra Offline
broncobra  Offline
ne
Nothings simple, and nothings plug and play. Except this. www.isispower.com.com It's not GM plug and play. But you don't have a GM.
Re: who makes reproduction wiring harness besides painless? [Re: lboggie] #572004
01/04/10 08:37 AM
01/04/10 08:37 AM
Arizona
az426john Offline
az426john  Offline
Arizona
Another vote for M&H but you do have to make your initial order through Year One.
If you have a 67 Hemi "B" body you will find that the wire for the oil pressure switch is in the wrong location. It comes located on the leg that runs to the front wiring harness on the drivers side and not the one that runs across the firewall. Additionally, the tach wire will be the wrong color (Grey w/black tracer) and run to the bulkhead connector for an in dash tach.
I worked with Darrin at M&H to fix my harness. They were great to work with. I sent them my old harness and some photo's. The new harness was returned with the problem solved. It appears that the blueprint is in error for this particular application. It added about 2 weeks to the process due to the Thanksgiving holidays. More additionally, you will be requested to pay for shipping. This is a small price for the service they provide and well worth it.
Re: who makes reproduction wiring harness besides painless? [Re: lboggie] #572005
01/04/10 01:11 PM
01/04/10 01:11 PM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
You didn't state the year/model of the car, but you may only get half a harness from Evans. Complete front to back harnesses (Engine, headlight, dash and rear lights) from YO can be as low as $750.00 with discount.
Re: who makes reproduction wiring harness besides painless? [Re: BJohnson] #572006
01/04/10 01:56 PM
01/04/10 01:56 PM
Chicago, Illinois
Devil Online penguin-006
Devil  Online Penguin-006
Chicago, Illinois
Painless makes a Mopar Universal Wiring harness. It isn't just drop in and go. There is another manufacturer of the same setup, a universal wiring setup with mopar colors. The name escapes me though.
For a direct swap in setup it is year one or evans.
Ryan
