Can you help me pick my suspension pieces?
#571959
01/04/10 12:47 AM
01/04/10 12:47 AM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I am trying to make some choices to upgrade the front suspension of my 1970 Dodge Dart for improved handling. I'm just looking to make it a bit more sure-footed. It's primarily a cruiser, with an occasional trip to the drag strip, but the steering does feel a little vague on the freeway, and I'd like it to corner a little better. Currently, I have stock front suspension components (all rubber bushings in good condition), a Firm Feel level II box, a Mopar Performance (Addco?) front swaybar, KYB shocks, and 15x6 Halibrand wheels with 205/65R15 radials. I've attached the printout from the last time I had it aligned - by a guy that has a reputation for being Mopar-savvy. Some of the components I'm considering, either individually or some combination, are tubular upper a-arms, Moog offset bushings, and the Dixie Restoration Parts adjustable strut rods. So, what are the thoughts out there?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Can you help me pick my suspension pieces?
[Re: MadMatt]
#571960
01/04/10 01:06 AM
01/04/10 01:06 AM
Posts: 22,696 Bitopia
jcc
Bitopia
First don't be so mad matt.
I like your #'s reg toe and caster, but Negative camber is a big improvement on handling especially turn in response, but the description on the readout describes negative camber, but I don't see any minus signs, not sure what I am missing.
For the money and the #'s you got, forget for now tube UCA, KYB's, 11/16" TR, adjustable struts, offset bushings and Boxing the LCA.
You do need a bigger/wider tire choice, and if you can accept the look, a bigger/better wheel. Beefier TB's at least to 1" are a must, with a better shock choice. Firm Feel 2 box is OK, maybe a 3 might be better. If all the suspension items are in good shape, I would make only the above changes and then re=evaluate. The Steering box would be the most difficult, but very well worth it, and you will not have to do anything over again for additional upgrades.
[Re: MadMatt]
#571961
01/04/10 01:07 AM
01/04/10 01:07 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Better tires!
Moog offset bushings --if you really want more caster. You are not bad now. If you have poly strut rod bushings you could shave them down and maybe get a little more caster. But you caster is not bad. bigger T-bars bilstien shocks
Dude, I'm in the garage right now. You want to see and touch most all that stuff come over ASAP. Car is on jackstand, and I've got suspension parts all over. You wanna see 5+ different front sway bars (73-76 style), bucket full of shocks, loose welded K-member, loose offset bushings, rear sway bars, on and on...
My PM is full, email pwall5@aol.com
I'm trying to fit these rims on the car. I think I'm going to have to roll the rear fender lips! They are virgins and perfect
[Re: OzHemi]
#571963
01/04/10 01:20 AM
01/04/10 01:20 AM
autoxcuda
So Cal
[Re: autoxcuda]
#571965
01/04/10 01:26 AM
01/04/10 01:26 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
And going to be closer on clearance it looks like when you get near full compression on the suspension Too bad you don't have time to skim some off the back face of the wheel to bring them in a little (it there was enough meat there) to save the lip Of course if you clearance the car now, gives you room for bigger wheels all the time.
[Re: autoxcuda]
#571966
01/04/10 01:27 AM
01/04/10 01:27 AM
MadMatt
Nampa, ID
Better tires!
Dude, I'm in the garage right now. You want to see and touch most all that stuff come over ASAP. Car is on jackstand, and I've got suspension parts all over. You wanna see 5+ different front sway bars (73-76 style), bucket full of shocks, loose K-member, on and on...
My PM is full, email pwall5@aol.com or call 310-855-4573
By better tires do you mean bigger, or actually better quality? I'm not sure I can fit much bigger in the wheel well without interference. Sounds like the concensus (so far) is also better shocks and bigger t-bars. Guess I'll look into that.
Thanks for the offer to check out your parts ware house. I'd love to take you up on that sometime, but right now I've got to try and get 2 sons back into school mode for tomorrow morning.
Be REALLY CAREFUL if you're going to roll those rear 1/4 lips. I had PERFECT 1/4 panels on my car and decided to roll the rears. I used the Eastwood tool roller tool. All I can say is .
99% of the people never notice, but my heart is broken about the outcome. If I come to visit I'll drive my car and let you see what happened.
[Re: MadMatt]
#571967
01/04/10 01:36 AM
01/04/10 01:36 AM
autoxcuda
So Cal
My car is an original 340-S automtic coupe numbers motor, no buildsheet. No rust ever except for the drain hole in front of the passenger rear tire (curvature of street)
I think I'm going to be firing up the sawzaw in about 15 minutes.
My plan is to cut 3/4 into the lip ever 3" for about 9" or so then slowly lip.
I've allready did this to the front. All metal is still there, just bent in.
[Re: OzHemi]
#571970
01/04/10 01:50 AM
01/04/10 01:50 AM
autoxcuda
So Cal
I'm going to Willow on Thrusday. But I will be away from my house on business until Wednesday night.
At the most I could skim off the back is like 3/8" tops. But the lugs are tapered and I dont think there is enough meat left. Plus the cost of shaving them down has got to be expensive.
What's your opinion of this?:
Not a whole lot of distance after the taper edge to the backside.
[Re: autoxcuda]
#571971
01/04/10 01:55 AM
01/04/10 01:55 AM
OzHemi
Garden Grove, CA
A shame they pocketed the seats down into the wheel or you could take plenty off How thick are they now, little hard to tell in the picture (the thickness from the mounting face to the lug nut face that is) Do they already have steel inserts in them ? (looks like it perhaps )
