Hesitation/dead spots on 03 ram #571818
01/03/10 08:55 PM
01/03/10 08:55 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
03 ram 1/2 ton, hemi. from idle to 2300rpm it runs fine. anywhere above it falls on its face and stumbles and at wide open throttle it seems to be running about 3/4 throttle, just doesn't seem to have all the hp there. I've done airfilter, sparkplugs,and fuel filter. Im lost any ideas?
Re: Hesitation/dead spots on 03 ram [Re: 68gtxsurvivor] #571819
01/04/10 01:08 AM
01/04/10 01:08 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
have you checked the tps or if you are getting correct fuel pressure to the injecters.G.L. BOB
Re: Hesitation/dead spots on 03 ram [Re: moparsquid] #571820
01/04/10 07:48 AM
01/04/10 07:48 AM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
try your basic tune up: plugs, wires
