I was looking at the spec's for the 360magnum rods and they are listed as being 6.117" long v/s 6.123" for the pre mag rods. Is this correct? also has anyone used the magnum rods in a pre mag build? is the big end the same size as the pre mag as far as witth(wide)
I can get a set of rods and pistons resized and hung with oversize pistons for 140$ this is a good deal if they will work in my 79 block and crank. how much comp will i loose with .006" further in the hole?
It will cost me an extra 100$ if I have to buy the pistons separate and have them hung on my rods not to mention my rods have not been resized.This is a truck motor low rpm towing.
