Gauge cluster removal #571654
01/03/10 07:24 PM
01/03/10 07:24 PM
North Carolina, U.S.
MattLipscomb Offline OP
Any Idea why it is the Gauge Cluster is loose but won't come out of the dash? Took all 6 screws out from the front but the cluster acts like its caught on something. Do I have to unplug the wire harnesses from the cluster before I try to remove it?
1970 Dodge Dart Swinger 225 Slant six 904 Automatic.
Re: Gauge cluster removal [Re: MattLipscomb] #571655
01/03/10 07:25 PM
01/03/10 07:25 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Aside from the wiring, don't forget the speedo cable.
Re: Gauge cluster removal [Re: OzHemi] #571656
01/03/10 07:34 PM
01/03/10 07:34 PM
So we have to disconnect all wires from the back along with speedo cable? I forgot to mention that the mission is to replace the light bulbs in the cluster only 2 work and night driving sucks.
Re: Gauge cluster removal [Re: MattLipscomb] #571657
01/03/10 07:50 PM
01/03/10 07:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You did disconnect the battery first didn't you?
Re: Gauge cluster removal [Re: stumpy] #571658
01/03/10 07:52 PM
01/03/10 07:52 PM
of course
Re: Gauge cluster removal [Re: MattLipscomb] #571659
01/03/10 08:10 PM
01/03/10 08:10 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
The wires might have enough slack in them, but the speedo cable may not. You can reach up under the dash from the bottom and just feel around to see how much 'rope' you have in it
Re: Gauge cluster removal [Re: OzHemi] #571660
01/03/10 08:52 PM
01/03/10 08:52 PM
NJ
440challenger Offline
NJ
amp gauge wires from the backside
Re: Gauge cluster removal [Re: MattLipscomb] #571661
01/04/10 10:42 PM
01/04/10 10:42 PM
Renton, Washington
TNTN63 Offline
TNTN63  Offline
Renton, Washington
Can you change the bulbs from the back?
I have a 1970 dart also and I had to drop the steering colume to clear the speedo part of the cluster. Once the colume is lowered the cluster can flip toward you and removed.
