HELP with Caltrac Setup ( rear hanger questions ) #571186
01/03/10 03:38 PM
01/03/10 03:38 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Not sure what to do to fix this,,,,would appreciate any comments,,,see pic below.
This is on a 65 Plymouth, Caltracs.
I want to be able to run the bar in the upper hole,,,but the bracket/hanger wont allow it,,, ( see pic ) The bar will not sit flush in the upper hole,,,and is running into a portion of the hanger/bracket
QUESTION:
I noticed there are "3" holes in the bracket,,,,, Are these 3 holes for "height" adjustment only ??,,,************, This is where it was set up when i got the car,,,,,
If i drop the caltrac/triangle into the bottom hole of the bracket,,,,i should have more clearance,,,BUT,,,,,Not sure if i have enough material to work with ,,, these brackets dont look super sturdy to me.
If i leave the caltrac/triangle where it is ( middle hole of the bracket),,,,i suppose i could shave the bracket some to allow more clearance to move the bar to the upper hole........??
I DONT want to raise the ride height any,,,the car sits a bit too high in the rear now with 1" over stock springs.....(again, i think putting the caltrac/triangle in the bottom hole of the bracket,,will raise the ride height ???? )
What do you guys think of just shaving some material off the bottom portion of the bracket,,,,to allow me not to bind when i put the caltrac bar in the upper hole ( see modified pic below ) ( do i need that bottom hole in the braket/hanger ? )
sorry for the long winded question....
thanks,,,
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571187
01/03/10 03:57 PM
01/03/10 03:57 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
no need to cut it where the green line is,
nothing will hit there.
The bolt in the back might hit or the top of the spring eye if you put it in the top hole.
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571188
01/03/10 04:10 PM
01/03/10 04:10 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
QUESTION:
Hi Doug yes those holes are for ride height adjustments. When me and Jason put the mopar spring relocation kit on the 65 at the time i was running mopar super stock springs. When i went to the caltrac setup with the moved in spring boxes. I could only run the spring in the lower hole. Which also raised the rear of the car to high up for my liking. So i moved the caltrac/triangle to the middle hole. Which is in the same spot as the factory front spring mount hole. But to get the caltrac/triangle to clear the front hanger i had to cut out the front spring hanger to fit them. I never tried running the bar in the top hole so i never cut the box out so they would fit.If you never plan to run the springs in the bottom hole i would say go to town on the spring boxes. I would go with the second pix to make your cut.If you have any more questions please fill free to pm me or I still look forward to hearing about the new engine for the 65. thanks Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: demon440] #571189
01/03/10 04:41 PM
01/03/10 04:41 PM
KENTUCKY
KENTUCKY
Demon,,,,it i put the BAR in the upper hole,,,it WILL clamp down and bind on the frame bracket,,,
Bobby,,,thanks for the input,,
I dont want to raise the ride height any,,,
I DO want to try the upper hole on the caltrac bars though,,,and see what it does,, ,, I should be able to remove what i need with a cut off wheel,, ,so i dont have to pull the springs off ( did that last year when i put in longer spacers for the front spring eye,,, what a pain,,,did that one alone on the garage floor,,,lots of swearing and drinking going on that night,,lol )
hint ( the new motor combo does have a "5" in it ,,, ) more clues later,,,lol
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571190
01/03/10 04:45 PM
01/03/10 04:45 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Caltracs makes a new set-up to clear the
relocation spring boxes.
Give them a call and see what they say.
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: demon440] #571191
01/03/10 04:48 PM
01/03/10 04:48 PM
KENTUCKY
KENTUCKY
? heading to their website now,,,,anymore info on this ? thanks Demon
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571192
01/03/10 04:49 PM
01/03/10 04:49 PM
doug, if you put the spring eye hole in the top hole it will lower your car some which will help you out if your minitubbed.
then you could use the upper hole on your caltracs.
when i ran caltracs in my 65 plymouth i went to the top hole on the spring perch which lowered the back of my car making it leave alot better.
Re: HELP with Caltrac Setup ( rear hanger questions ) #571193
01/03/10 04:57 PM
01/03/10 04:57 PM
KENTUCKY
KENTUCKY
Chris,
wouldnt that drive the upper hole on the caltracs higher up into the bracket ?
the car sits a bit high in the rear,,,and lowering it would be better,,i agree,,i might have some tire clearance issues in the wheelwell if i drop the ride height ,,, has a 31x15x10.5 tire now,,,arrgghhh,,,
thanks for the info,,,,
you could just send me your 65 (plymouth),,,and let me try it out....lol
Doug
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571194
01/03/10 05:14 PM
01/03/10 05:14 PM
Chris,
Doug
drop the rear of the car with the bolt in the top hole, then you'll be able to get to the top hole with the caltrac bar, it will give you less of a rake in the back and better weight transfer.
ask me how i know?
after i lowered my car in the back, 60 foots were much better.
sorry i love my 65 plymouth too much.
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571195
01/03/10 05:17 PM
01/03/10 05:17 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The new cantilever from Caltrack won't help this situation. That only helps the force bolt/bar area that swings inside the boxes.
The area of concern for this is the arc that the bolt head swigs on when the force is being applied. Any grinding that needs to be done will be following that arc to the forward/front side of the car.
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: RobX4406] #571196
01/03/10 05:22 PM
01/03/10 05:22 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I couldnt get on the top hole in the spring boxes on mine......... top side of the spring eye was hitting the frame......
Mopar Performance
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: RobX4406] #571197
01/03/10 05:23 PM
01/03/10 05:23 PM
KENTUCKY
KENTUCKY
The area of concern for this is the arc that the bolt head swigs on when the force is being applied. Any grinding that needs ot be done will be following that arc to the forward/front side of the car.
hmmmmm, this could be the same for mine,,,Im out to the frozen garage to lay under the car and check it out.
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571198
01/03/10 05:25 PM
01/03/10 05:25 PM
RobX4406 Offline
RobX4406  Offline
Edited my post with some nasty picture for you.
I'm still sitting no matter what you say!
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: RobX4406] #571199
01/03/10 05:37 PM
01/03/10 05:37 PM
KENTUCKY
KENTUCKY
LOL,,,almost spit on the keyboard Rob,
(hey,,,when the time comes,,,i'll give ya the Moparts discount on the exam,,,lol, )
( i even photo-shopped my lab coat on,,,lol )
ps,,also checked the clearance issues that 540 mentioned,,,looks like the spring/eye would hit at the top of the hanger on mine also,,,i assume this is a MP item,,,wondering what Chris' has on his,,perhaps a different bracket....with more clearance....
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: RobX4406] #571200
01/03/10 05:40 PM
01/03/10 05:40 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
going to the top hole would be worse anyways IMO....
Mopar Performance
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: moparniac] #571201
01/03/10 05:42 PM
01/03/10 05:42 PM
KENTUCKY
KENTUCKY
top hole on the caltracs ?
too much hit ?
mine is just a 10 sec bracket car,,nothing fancy...top hole would be too much for it ?
i have never tried it,,,have been trying to learn different things on the suspension a bit,,,figured it couldnt hurt to try,,,until i looked at the car,,and saw some fabrication might be needed...
540' looks like the exact set up , clearance as mine,,,
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571202
01/03/10 05:46 PM
01/03/10 05:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
top hole of the front spring box..........
Mopar Performance
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: moparniac] #571203
01/03/10 05:50 PM
01/03/10 05:50 PM
RobX4406 Offline
RobX4406  Offline
OMG, you even have gloves on with that lab coat... RUN!!!
540's pic is consistent with what I was trying to convey.
As a side note. Trying to put the spring eye bolt in the top hole of the relo boxes would be murder.
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571204
01/03/10 07:49 PM
01/03/10 07:49 PM
mopar65 Offline
mopar65  Offline
too much hit ?
I would say yes to this. I for got to say that when i had the front spring in the bottom hole and the caltrac bar in the top hole. My car would blow the tires off it no matter what setting i used with the bars. also at this time i was running some used M/T 29.5x11.5x15 slicks. So i moved the bar to the bottom hole and the car would hook better but not good enough.SO after i moved the the front spring to the middle hole. I called calvert and told him what my car was doing. He recommended i run the bar in the bottom hole. After doing what he said i was running 1.44-1.45 sixty foots. So i left it there and raced it like that until you bought the car. I wish i would of tryed the bar in the top hole after i put the new slicks on but never did.
Doug i would cut the part out like what 540 posted and give it a try you never know the car might like it.If i can come up with the money i want to build a 512 for my dart. best of luck this year to you Doug. Bobby
Doug here is a pic of the 65 right after i put the cal trac kit on and with the front spring in the bottom hole. thanks Bobby
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: mopar65] #571205
01/03/10 07:55 PM
01/03/10 07:55 PM
KENTUCKY
KENTUCKY
Thanks Bobby,,,,that is a old pic eh ?
I dont know what the car will do in the top hole,,,might not like it,,,but easy enough to try,,,,and i can trim the hanger's pretty quick,,,and see,,,,plus i dont think i will move the springs to the bottom hole anyways,,,(no room to move them up either,,,so i think i am stuck where they are at)
Last year i was getting consistent 1.41-43's 60',,,better as i brought up the launch RPM,,,,
Going to throw some stuff at the car and see what it likes,,,eg,,,Calvert front shocks,,,play with the rear shocks,,,video tape the car a bit to see what it is doing,,,new slicks in the spring,,,etc,,,
My goal this year is to get UNDER 1.40 for a 60',,,going to try....
512 ? sounds cool.........
