Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571206
01/03/10 07:59 PM
01/03/10 07:59 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Thanks Bobby,,,,that is a old pic eh ?
I dont know what the car will do in the top hole,,,might not like it,,,but easy enough to try,,,,and i can trim the hanger's pretty quick,,,and see,,,,plus i dont think i will move the springs to the bottom hole anyways,,,(no room to move them up either,,,so i think i am stuck where they are at)
Last year i was getting consistent 1.41-43's 60',,,better as i brought up the launch RPM,,,,
Going to throw some stuff at the car and see what it likes,,,eg,,,Calvert front shocks,,,play with the rear shocks,,,video tape the car a bit to see what it is doing,,,new slicks in the spring,,,etc,,,
My goal this year is to get UNDER 1.40 for a 60',,,going to try....
512 ? sounds cool.........
Holler if you need any help! I need to get out and lay under mine this week too but 7 degrees I am not liking on cement.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571207
01/03/10 08:05 PM
01/03/10 08:05 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
That pick was taken around 1998-2000 time frame. Doug what about buying a set of stock ride height calvert springs? That would lower the back of the car down and then you could lower the front down some to.I say this as long as those springs have been on there its a wonder that they are not worn out. If i can get my old computer working i have some pics of the car when it sat low with mopar super stock springs on it. Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: RobX4406] #571208
01/03/10 08:07 PM
01/03/10 08:07 PM
OMG, you even have gloves on with that lab coat... RUN!!!
540's pic is consistent with what I was trying to convey.
As a side note. Trying to put the spring eye bolt in the top hole of the relo boxes would be murder.
explain this statement to me. because mine was in the top hole and i 60 footed 1.37 with caltracs going 10 teens footbraking.1.42 60 foots with more of a rake like dougs car sits now,my car wouldnt 60 foot until i lowered the rear.
putting it in the top hole lowers the car and will give less of a rake and more travel in the rear suspension and more room to go to the top hole.
Re: HELP with Caltrac Setup ( rear hanger questions ) #571209
01/03/10 08:11 PM
01/03/10 08:11 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Chris ,,the dodge and plymouth sure do have a different rake,,, mine looks to sit more like your dodge now,,,your plymouth is down there...
I think mine would like to sit lower,,,and would likely act better,,,the current springs are 1" OVER stock,,,do you know what springs you have (rating) when you got the 1.3x 60's ?
thanks for the pics,,,,i'll take the dodge too (lol)
hmmmmmm,,how old are those springs Bobby ?
Kyle,,,come on,,,,Kentucky,,,cold,,lol,,,i have a heater in the garage,,,works well,,,give me a holler' if you need some help....
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571210
01/03/10 08:22 PM
01/03/10 08:22 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I may need to come over just to get some experience with the setup as I plan to buy the springs and caltracs as well.
I'll holler when I need the help and you can bring the LP too for a jam session.
'71 Dodge D100
'70 Dodge W100
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571211
01/03/10 08:24 PM
01/03/10 08:24 PM
mopar65 Offline
mopar65  Offline
Doug i am guessing they are around 11 years old. I think i bought the car around 1995-96 and put the caltracs on around 1989-2000
Chris again all i can say about your cars is
Bobby
Re: HELP with Caltrac Setup ( rear hanger questions ) [Re: 69CHARGERMD] #571212
01/03/10 08:49 PM
01/03/10 08:49 PM
doug, mine were -1" over stock springs but by lowering the front eye spring you can adjust the ride height and also if you take out preload you could lower it a little more.
what do i know i'm just a fish peddler.
Re: HELP with Caltrac Setup ( rear hanger questions ) #571213
01/03/10 10:50 PM
01/03/10 10:50 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I had this problem and Calvert sent me a pin instead of a bolt that used C-clips instead of a nut. Was close to flush on the bracket and allowed it to pivot. I still notched the bracket. They sent me that pin free also.
