Re: GPM flow
[Re: AndyF]
#570852
01/03/10 04:13 PM
01/03/10 04:13 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
for 20+ years I've been a big advocate of using a ported stock pump...plenty of volume and pressure at higher RPM and a little less drag on the motor. 440Jim has done a great job documenting all the porting 'tricks' and I believe he still runs one on his 7200+ RPM 511 which I believe is essentially the same things I did on our Enginemasters 470 Pump. Do a search within the past couple months and you'll find great pics and step by step. I recently ported the #5 cap and all the internals similarly on my last small block and use the stock pump with a rear sump truck pan on my 341" Rocky. Hot rodding is all about efficiency, the oiling system is a parasitic drag on the Cam and the distributor which puts more load on the crank through the timing chain. Using ahigh volume pump that uses the same internal "head" dimensions as a stock pump is kinda like building a stroker with stock heads.....With a HIGH performance application you typically are insuring the oil supply pressure and volume can keep up with the increased crank/valvetrain speed. Just like porting a head makes an engine more efficient at high RPM, I simply apply the same logic to the oil pump. I always wondered what is the point of a 1/2" pump pick-up when the internals of the pump inlet and outlet passages themselves (including the HV) were barely 3/8"? As the discharge pressure of the pump hits the crank there is a cumulative drop of pressure as oil "bleeds" through all the orifices of the Mains and rods as well as up the lifter galley....in essence that is "fixed" and predicable by the blueprinted specs of the system. Fluid dynamics (simple hydraulics) will dictate that any change to an upstream dischage orifice size will have a proportional effect on anything down the line. By making the pump more efficient you are effectively guaranteeing a more efficient pump flow to and discharge supply pressure and volume to the system. Back 30 years ago Bracket motors ran heavy 40 and 50WT racing oils so bigger pumps were required just to feed the large clearances and bigger passages at the higher RPM, with modern oils (and typically lighter stronger components) this is seldom the case anymore.
Re: GPM flow
[Re: AndyF]
#570855
01/03/10 07:56 PM
01/03/10 07:56 PM
Posts: 4,209 New York
polyspheric
New York
Old engineering formula: total cross-sectional area of all leaks × 30 = pump volume. Yes, it's linear: running .003" instead of .002" requires almost exactly 50% more oil volume.
Remember that the leak pressure from a working bearing at speed is many times higher than "gauge" pressure, can run into the high hundreds.
Lower pump volume is limited to 2 choices: 1. reduce the gear area 2. reduce the pump speed
For #1, the height of the gear stack is the easiest to do, as Andy said - just shorten the gears, shafts and body and put the cover back the same way. Extra plus: your bypass valve is now more efficient (= bigger proportion of volume). Why not just use a low pressure spring? Because every single molecule of oil still goes through the gears.
For #2, (obviously) an external pump can just change the pulley sizes to slow the pump down as much as you want. For people with money and using a crank trigger, you could replace the cam and pump gears with a shallower pitch and run it at any ratio you want since it's not timed (unlike the ignition).
Boffin Emeritus
Re: GPM flow
[Re: TS3303]
#570856
01/03/10 08:00 PM
01/03/10 08:00 PM
polyspheric
New York
the oil system is also for removing heat
True, and should be considered for any longer race than 30 seconds. Since the volume passed through the cooler (if any) is reduced, the cooler rejects less heat. The cure is to keep the oil in the cooler longer (more passes), and/or expose more cooler area to the airstream (ducting).
Boffin Emeritus
Re: GPM flow
[Re: go green]
#570857
01/03/10 08:15 PM
01/03/10 08:15 PM
polyspheric
New York
Very long post on this at SpeedTalk. What actually provides pressure at the bearing is viscosity × local speed differential × the distance to the closest leak (which is why grooved bearings reduce oil pressure). The pump pressure is needed to refresh whatever is leaked away, but very little to do with the bearing support itself. If it were practical, you could pump acetone through at 2,000 psi and be safe (except for the film's load capacity). The "10 psi per 1K RPM" is simply a good guess at the total leak rate of common engines - if the pump supplies this, the pressure continues to rise with RPM (never mind what the gauge says) unless the pump can't keep up with the leak, then you drive over the crank. So, RPM is a factor? Only with the main bearings. ??? The mains are stationary, the journals rotate at 100% engine speed (duh), but how fast does the rod journal rotate? Trick question, the relative speed of the rod journal and bearing is lower, and stops and reverses during the crank stroke. The rod is only fully rotated vs. the block, not to its journal. Then, how does it work? Damned if I know, because dipper rods (= almost no delivery pressure) worked very well for 50 years as long as the bearings were big enough. The short oscillation period before reversal is evidently enough as long as it gets oil. Example: pre-1953 Chevy L6 rod bearing is 2.311" ID and about 1.024" wide, gets about 20 hp each and 4,000 RPM in service and does fine.
Boffin Emeritus
Re: GPM flow
[Re: Streetwize]
#570858
01/03/10 08:29 PM
01/03/10 08:29 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
X2, This is my setup with a 4.25 arm, 10w-30 @ 8700 every pass. never had a problem.
8.30's @3400 lbs
