water pump "riser" ??? #570673
01/03/10 10:38 AM
01/03/10 10:38 AM
moparx Offline OP
moparx  Offline OP
does anyone remember who makes, or used to make, a water pump for sbc[ ] that was cast with a body that was 3-4" "taller" than stock that re-positioned the fan in a higher position ? i just want to see how they did the casting. i have something in mind along those ideas i mite want to try. thanks in advance !
Re: water pump "riser" ??? [Re: moparx] #570674
01/03/10 04:07 PM
01/03/10 04:07 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Re: water pump "riser" ??? [Re: Mopar Ron] #570675
01/03/10 06:11 PM
01/03/10 06:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: water pump "riser" ??? [Re: Mopar Ron] #570676
01/03/10 06:13 PM
01/03/10 06:13 PM
moparx Offline OP
moparx  Offline OP
that's the one ron ! thanx! i'm in the process of fabbing one to disguise a sbe. i have 4 street l's [square block ,used as hydraulic fittings]. i "think" i can use the block fittings plus 1" 1/8 wall tube to "raise" a shortypump to use in a model A roadster pu. project for my cousin charlie. coments anyone ? ron, i couldn't find a price on snowwhite's site. any idea ? and, yes, i'm gonna take pics of this deal, cause i rteally thimk it will be neat........
Re: water pump "riser" ??? [Re: RodStRace] #570677
01/04/10 10:10 PM
01/04/10 10:10 PM
moparx Offline OP
moparx  Offline OP
Zips
http://www.southernrods.com/categories/heating-and-cooling/water-pumps/products/product-1845.html
BTW as you said, SBC=
that looks interesting too. i always get conned into projects for my "pals"....... nowonder i don't get anything accomplished for myself....
Re: water pump "riser" ??? [Re: moparx] #570678
01/07/10 12:20 AM
01/07/10 12:20 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wow weird piece wonder if that would fit the hot heads chevy water pump adapter on my early hemi to raise it up,,,it says it requires a 6 cylinder water pump,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: water pump "riser" ??? [Re: fstfish66] #570679
01/07/10 09:33 PM
01/07/10 09:33 PM
moparx Offline OP
moparx  Offline OP
the zips one rodstrace links to uses the 6cyl pump, but i noticed the snowhite one ron mentioned uses an opal pump that you drill out the mounting holes from 7mm to 11/32". that's according to their instruction sheet[s]. the one thing i don't like about either riser, is the way they both mount the alternator and ac pump [if used] up high. i like to mount all the stuff as lo as possible so you don't notice it as much. i have a couple of ideas floating around in my [tiny little] brain and i need to gather up some material to test my theory. i'm thinking those risers "might" fit hot heads adapters, but i wouldn't be suprised if the adapter and/or the riser would need some slight mods to go together correctly.
Re: water pump "riser" ??? [Re: moparx] #570680
01/07/10 11:57 PM
01/07/10 11:57 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
well keep us posted please,,,
2015 cherokee
2013 R/T classic
