Re: How much power?
[Re: Dart of Denmark]
#570626
01/03/10 08:47 AM
01/03/10 08:47 AM
Posts: 1,262 Netherlands
72Challenger
Netherlands
Depending on the flow# I would guess it to put out around 800-830hp. Just a guestimate based on your info compared to what mine 'should' put out. With a lightweight Dart it could get you into low 9's / high 8's eventually?
Re: How much power?
[Re: 72Challenger]
#570627
01/03/10 09:06 AM
01/03/10 09:06 AM
Posts: 87 Denmark
Dart of Denmark
Denmark
I think this is little cheating! engine comes from your nieghbor!!
Re: How much power?
[Re: Quicktree]
#570629
01/03/10 10:01 AM
01/03/10 10:01 AM
Posts: 87 Denmark
Dart of Denmark
Denmark
good power but why did you go with the sr heads? I would think they are holding you back on HP
Engine is build with sr-heads by hensley.I have bought it used.
Re: How much power?
[Re: 72Challenger]
#570631
01/03/10 11:07 AM
01/03/10 11:07 AM
Posts: 87 Denmark
Dart of Denmark
Denmark
Whaha didn't even think of it that way...now you say it, yes you got it from Roel running low to mid 9's. You got yourself a good, low maintanance motor! My buddy called roel for it at the day you came to pick it up so you were right on time. Good luck with the combo and hope to see it run at our strip someday!
Thanks! Not impossible that we come down for a race
I have to say Roel is a nice guy do deal with!
Re: How much power?
[Re: 72Challenger]
#570633
01/03/10 01:54 PM
01/03/10 01:54 PM
Posts: 87 Denmark
Dart of Denmark
Denmark
Thanks!
Your Dart would be a nice add to the already nice moparfield at our strip including cars like; * new build superbird * new build nostalgia funny * rebuild challenger * rebuild dart * chargers, roadrunners, superbee, cudas etc. * many more I forgot
Then bring along your 'neighbour' with a blown challenger. Or at least a couple of years back some guy was building one from who I bought a 727 back in the days.
That blown Challenger was written about bigtime!! But i have never seen it on a dragstrip
Have you some homepage adresses to dragstips down there??
Re: How much power?
#570634
01/03/10 03:08 PM
01/03/10 03:08 PM
72Challenger
Netherlands
Well you've got Hockenheim in Germany (had luckau too but that's closed this year) and Snata Pod in the UK both of which could be found easliy if you dn't have them already. At our place it's in the northern part of Holland, town called Drachten, for which you can find info on www.explosion.nl but if there's any extra info you would like just shoot me an pm or email. Would be neat if you guys could make it. As for the Challenger I can't remember the guys name but he had a n/a hemi first but even before that one was fired up he decided to get some more motor by getting, I believe, a 10/71 blown hemi.
Re: How much power?
[Re: Cab_Burge]
#570637
01/04/10 02:47 PM
01/04/10 02:47 PM
Posts: 87 Denmark
Dart of Denmark
Denmark
My 527 motor, 4.375 x 4.375 with M.W. port SR with a single 1050 on a 440-2 intake with a tapered the adapter and 12.8 to 1 comp. ratio made 875 HP on a Studka and only 775 on a DTS dyno later that year with no other changes I beleive the rsults from the DTS more than the ones from the Studka
Can you tell me more about your heads? Mine are stage 3 ported by Hensley but don't now anyting about them! I have tryed to contact them byt no succes I'm thinking maybe a set cnc ported 440-1 is a good invest?
