Re: Honing plates
[Re: barracuda man]
#570089
01/02/10 05:31 PM
01/02/10 05:31 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Are they needed when doing a freshen up.No bore work just a hone.My machinest don't have them anyway.What do ya'll think.
FWIW, years ago i had a 440 block bored and honed with plates. Pulled it down and just had a de-glaze done to re-ring. They didn't use plates for this. Ran pretty much the same ET (sometimes slightly faster, sometimes slightly slower). Nothing that I can pin to the plates.
It's always best to use them for any honing operation as it's proper procedure.
Re: Honing plates
[Re: Dyno1]
#570090
01/02/10 05:36 PM
01/02/10 05:36 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
If the block was originally done with a plate, it should be redone with a plate. Shadows in the cylinder walls if the block is thin. Good luck. Dyno
There is NO Other Option!
Re: Honing plates
[Re: torkrules]
#570091
01/02/10 06:11 PM
01/02/10 06:11 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Touching up the finish with a ball hone (Flex hone) is a completely satisfactory practice. Since it followed the same contour, it didn't change the shape of the cylinder and when the heads were torqued down it returned to it's original cylindrical shape.
