318 crank pulley on LA 360 balancer #569963
01/02/10 02:28 PM
01/02/10 02:28 PM
Oshawa, Ontario, Canada
MoparSam Offline OP
MoparSam  Offline OP
Hi All,
Swapping a 360 to replace my old 318. I went to install the crank pulley off of the 318 and some of the bolt holes do not line up with the holes on the 360's balancer.
Can i just open up the 3 holes a little or do I need to find the correct 360 crank pulley?
Thanks,
MoparSam
Re: 318 crank pulley on LA 360 balancer [Re: MoparSam] #569964
01/02/10 02:38 PM
01/02/10 02:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Should only be 1 bolt hole off, that needs to be elongated,....SmBlk Crank pulley went Asymetrical on the bolt pattern in late 1971 IIRC,....will not affect the balance in anyway
Re: 318 crank pulley on LA 360 balancer [Re: DAYCLONA] #569965
01/02/10 03:24 PM
01/02/10 03:24 PM
MoparSam Offline OP
MoparSam  Offline OP
Thankyou DAYCLONA
That worked out fine.
Moparsam
