69 B body vacum pod #569941
01/02/10 02:10 PM
01/02/10 02:10 PM
fullfloater Offline OP
Where does the vacum pod go on a 69 b body with A/C .I know on a 70 b body it goes under battery tray ,but not sure of 69 ,Thanks
Re: 69 B body vacum pod [Re: fullfloater] #569942
01/02/10 08:06 PM
01/02/10 08:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I do not think that 69 had one .
Re: 69 B body vacum pod [Re: JohnRR] #569943
01/02/10 10:39 PM
01/02/10 10:39 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I remember the vacuum hose going straight to the intake vacuum port.
Re: 69 B body vacum pod [Re: rrunner] #569944
01/03/10 06:47 PM
01/03/10 06:47 PM
Service manual is showing it has a vacum pod with A/C ,but not showing location
Re: 69 B body vacum pod [Re: fullfloater] #569945
01/03/10 07:59 PM
01/03/10 07:59 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I see that for C bodies, but not for B bodies. What page are you looking at? C bodies did have the vacuum canister, got one here from a 69 Fury I parted.
Re: 69 B body vacum pod [Re: rrunner] #569946
01/17/10 12:34 PM
01/17/10 12:34 PM
You are correct my manual shows it for c body not b body ,but i have 2 vacum hoses coming out of gromelet in firewall ,one is short whitch goes to intake for vacum ,i have another vacum hoses that is long enough to go in front of radiator ,can,t remember where it went ,car has electric pump w/d washer ,so i know its not this hoses ,its a vacum hose and it has me stumped ,it sure looks like it went to a vacum pod in front of radiator or under battery tray ,i am short on vacum to run vacum operated doors on heaster /AC etc ,i been fighting blower motor problems ,finally got this lined out ,bad controller and switch resistor ,any ideas A/C car 69 B body thanks
