Melted My Shifter Cable - Need a Longer Cable #569467
01/02/10 10:26 AM
01/02/10 10:26 AM
United States
STLDuster Offline OP
United States
I started my car the other day and my shifter was stuck. It turns out I melted the stock 5' cable that came with my Turbo Action Shifter Cable.
So I am going to rout the new one differently (further away from the exhaust).
I am planning on ordering the 8' cable from Turbo Action. But wanted to know if there were any other cables out there I could use.
I had read where some one had one made that put the stock cable to shame, but cant for the life of me cant remember where that was.
Anyone ever replaced a Turbo Action Cheetah Shifter cable?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Melted My Shifter Cable - Need a Longer Cable [Re: STLDuster] #569468
01/02/10 10:29 AM
01/02/10 10:29 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Are you SURE that it was the heat that did-it-in? .... there are many instances that a improperly electrically grounded engine is the problem.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: dOoC] #569469
01/02/10 11:16 AM
01/02/10 11:16 AM
United States
United States
Yeah, I had installed the shifter before I installed the exhaust. The shifter cable was really close to my X pipe. After I moved the car around some the shifter cable came in contact with the exhasust pipe and I didn't know it until it was too late.
I had read about the shifter cable being used as a ground and melting. So I grounded the engine as best I could. I used a couple of 2-gauge ground cables on both sides of the front of the block, and the original ground cable on the fire wall.
I have plans of adding one to the transmission but have not figured out how I want to do it.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: STLDuster] #569470
01/02/10 11:37 AM
01/02/10 11:37 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
A longer cable may not be what you want. Having all that excess length to tie back is a potential problem. In my experience with B&M shifters and headers I go with the shortest cable that works- A simple loop from the shifter to the tranny. Tie it back and wrap any potential heat absorption areas with header wrap.
Keep old mopars alive.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: 2boltmain] #569471
01/02/10 11:57 AM
01/02/10 11:57 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sometimes a shorter cable will route better than a longer one. In my BB scamp a 4' cable lasted about two weeks where a 3' lasted for a year. It routed closer to the block and out of the way of the exhaust.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: STLDuster] #569472
01/02/10 11:58 AM
01/02/10 11:58 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I melted a B&M cable once by too many powerbrake burnouts in too short a time. Replaced it with the heavy duty cable (the red one), and wrapped it with heat wrap where it crossed over the exhaust (no choice). Also secured it to the floor pan in the same location so as to get an inch or so of clearance to the exhaust.
Never melted again.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: Pacnorthcuda] #569473
01/02/10 01:55 PM
01/02/10 01:55 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I had the same issue With my B&M and tried an 8' cable as well. It didn't even make it one pass before it melted. I went W/ a 4' cable and haven't had a problem since.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: WILD BILL] #569474
01/02/10 02:25 PM
01/02/10 02:25 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
http://www.heatshieldproducts.com/heat_shield_sleeve.php In a pinch i,ve used aluminum foil wrapped loose and wire tied at the hot spot.
Re: Melted My Shifter Cable - Need a Longer Cable [Re: earlybee] #569475
01/02/10 08:46 PM
01/02/10 08:46 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the longer cable worked for me as long as u route it away..mine came out of the shifter ran along the left fender towards the front and wrapped around the gear box,headers and ran along the engine oil pan...worked out fine..
Re: Melted My Shifter Cable - Need a Longer Cable [Re: STLDuster] #569476
01/02/10 11:49 PM
01/02/10 11:49 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Maybe a different routing?? Mine goes from the shifter thru the firewall,across the trans bell housing and down to the lever.
Nautilus Racing-
Re: Melted My Shifter Cable - Need a Longer Cable [Re: STLDuster] #569477
01/03/10 12:52 AM
01/03/10 12:52 AM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
