Re: Starter staying on
[Re: stumpy]
#569380
01/03/10 01:03 AM
01/03/10 01:03 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
When it's cranking with the key not in the start position. Unplug the small lug on the starter relay. It's hot during cranking from the ignition switch during cranking. If it stops the problem is before the relay. If it still cranks, it's the starter relay sticking.
[Re: derekeh]
#569381
01/03/10 08:28 PM
01/03/10 08:28 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
Yes that is what it is doing. Even with the key off the starter is still turning.. just not engaged.
I can't help, but just be thankful it wasn't still engaged and happened while you were driving down the interstate. Jim
