Keith Black KB71160 Billet Oil Pump
#569358
01/02/10 08:21 AM
01/02/10 08:21 AM
I'm thinking of trying this oil pump in my new motor and was wondering if anyone has used it and what do you think of it. KB website doesnt have any pictures of it. anyone have any pictures of what it looks like? or maybe the Ray Barton Pump or keep the Titan i have. any suggestions.new motor is getting close to going in.
Re: Keith Black KB71160 Billet Oil Pump
#569360
01/02/10 11:04 AM
01/02/10 11:04 AM
Posts: 19,612 Las Vegas
Al_Alguire
Las Vegas
I have the non billet version, works for me.
Post deleted by Defbob
#569361
01/02/10 11:07 AM
01/02/10 11:07 AM
[Re: go green]
#569363
01/02/10 01:50 PM
01/02/10 01:50 PM
Posts: 91 under a rock
flathood
under a rock
I have a system one oil pump. The guys there were excellent and shipped my pump in two days. It comes flow tested and pressure set to what ever you want. Dont over look this company they were good to me.
The ultimate wet sump Hemi oil pump 7075-T-6 aircraft grade aluminum Hard black anodized Hand fitted, blue printed gear sets Adjustable oil pressure from 80 to 250 psi Flows an incredible 30 gallons per minute! Used by 8 out of 10 professionals using wet sump Hemi engines Top Fuel Hemi pump flows an incredible 34 gallons of oil per minute
GOGREEN,do you use a swinging pick up or static?How much is that pump?I also have an old system one oil filter I might use.Will the oil filter handle 30 GPM?
[Re: Defbob]
#569364
01/02/10 03:39 PM
01/02/10 03:39 PM
Get a Warfish pump. I take it the Titan pump is drysump like what Dean Stevens had?
the TITAN i have on my 588 is a wet sump oil pump with Static pickup. thanks for all the replys.
[Re: go green]
#569365
01/02/10 03:44 PM
01/02/10 03:44 PM
gogreen, does system 1 make a wet sump pump?do you have a part #? looks like a nice piece.
[Re: go green]
#569367
01/02/10 05:05 PM
01/02/10 05:05 PM
Part #235-900780-2 1.8 gear.
It sells for $1200.00 be he sold me my for $1000.
You can get it with a #20AN inlet or a #16AN inlet.
I have a static pickup with baffles in the pan.
Give them a call .
thanks,i like that setup,nice and simple.looks like the way to go.
[Re: 68roadrunner]
#569369
01/02/10 09:30 PM
01/02/10 09:30 PM
flathood
under a rock
you better check. the system 1 filter i have is only good for 24gpm.
So if that the case,what oil filtration system is used with these top shelf pumps in the 28 to 33gpm range ??
[Re: hemi-itis]
#569374
01/03/10 01:03 PM
01/03/10 01:03 PM
Posts: 5,875 communist bloc of new jersey
jamesc
i really don't know and am not preaching to run a stock pump just that i think guys really get carried away with this one. i used to think that the bigger the pump the better, in reality the best pump is the smallest one that will develop the desired pressure for a given crank speed. if you use a stock pump with a spring (or adjustable setup like milodon sells) and get the pressure you want than that should be all the pump you need. for the most part it's been the suction side of the system that's been restrictive so you end up going to an external feed. personally i think the pump covers like the one Muscle Motors is selling with a stock or HV pump would fill most needs. i would prefer to use an iron pump but there aren't any that have an external feed like the milodon, i don't really care for using the spacer setup. a stock style HV iron pump with an external feed provision like the milodon and one of the external feed MM type covers with cast in filter adapter would be as far as i could see going before switching to a dry sump anyhow. Andy Finkbeiner did some oil pump research and i'm sure is more qualified to offer an opinion but i get the impression the data he collected is somewhat proprietary. i've said it before, racers are like crows we like shiny objects, CNC anodized aluminum components are visually stimulating BTW i would say the milodon setup while not pretty should satisfy just about any situation as long as you make sure there aren't any leaks on the suction side which would leak air and get bubbles in the system. imho they should definitely retire that hokey filter adapter setup though.
