16 volts Alternator #568581
01/01/10 05:41 AM
01/01/10 05:41 AM
Denmark
Dart of Denmark Offline OP
Denmark
Is anybody her running a 16v alternator with 12v batt?
Is it a pain for 12v battery?
Im thinking of this: http://www.summitracing.com/parts/PWM-8176/
Re: 16 volts Alternator [Re: Dart of Denmark] #568582
01/01/10 08:23 AM
01/01/10 08:23 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Great looking Dart! Not running a 16 volt, but we have an adjustable voltage regulator that you can dial in your desired voltage output. Pretty cool unit.
Here is one available online. Looks like it is what you may need..Oh..did I say great-looking car?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 16 volts Alternator [Re: sunroofgtx] #568583
01/01/10 09:03 AM
01/01/10 09:03 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
why would you do that?? I am no expert but a 16v alternator charges at 18+ volts don't think your 12v battery would like that too much...
Re: 16 volts Alternator [Re: sunroofgtx] #568584
01/01/10 02:50 PM
01/01/10 02:50 PM
Denmark
Denmark
Thanks for comments
Can not find the adjustable voltage regulator
Regards Tommy
Re
Re: 16 volts Alternator [Re: Dart of Denmark] #568585
01/01/10 03:37 PM
01/01/10 03:37 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
What's wrong? Can't read my mind?
I forgot to post the link.. Sorry..
http://www.batteriesareus.com/index.php?main_page=product_info&products_id=366
Re: 16 volts Alternator [Re: sunroofgtx] #568586
01/01/10 04:52 PM
01/01/10 04:52 PM
Denmark
Denmark
Thanks for the link
Don't esy to read mind cross atlantic sea
Re: 16 volts Alternator [Re: MegaDart] #568587
01/01/10 04:55 PM
01/01/10 04:55 PM
Denmark
Denmark
To give MSD ignition extra power but i don't now if it's worth it
Re: 16 volts Alternator [Re: Dart of Denmark] #568588
01/01/10 05:52 PM
01/01/10 05:52 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
SpeedwayMotors.com sells a step up box that boosts 12v to 17.5v for the MSD. Only 2 or 3 passes on mine but noticeable increase in spark zap. Plugs love it.
The little old lady from Pasadena is back!
Re: 16 volts Alternator [Re: Barnstorm] #568589
01/01/10 06:02 PM
01/01/10 06:02 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Tommy, I run 16v in the Firebird and absolutely love it!! But I do NOT run an alternator. I know some guys that do with good success but 18+ volts to sensitive electronics scares the $%^&*( out of me!!
Re: 16 volts Alternator [Re: MegaDart] #568590
01/01/10 07:00 PM
01/01/10 07:00 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I run the powermaster XS-volt system. Nothing spins over your engine like a 16 volt setup.
Most new electronics are good to 20 volts .
I have a sheetwack of electronics and have had no issues running 16 volts.
I have the adjustable alternator and my car runs at 18 volts everywhere. I spin the alternator to around 15000 RPM. Once you go 16 volts you will never go back to 12 volts.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: 16 volts Alternator [Re: Barnstorm] #568591
01/02/10 06:37 AM
01/02/10 06:37 AM
Denmark
Denmark
That was a nice little piece
Re: 16 volts Alternator [Re: MegaDart] #568592
01/02/10 06:42 AM
01/02/10 06:42 AM
Denmark
Denmark
16v battery and 16v chargers are BIG $$
in europe
Other wise i will go that way!
Re: 16 volts Alternator [Re: Dart of Denmark] #568593
01/02/10 07:03 AM
01/02/10 07:03 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
With the proper wire size to the starter , a 60 amp one wire alt, and an Optima yellow top my 557 Hemi spins over like this all the time .
Chryco
http://www.youtube.com/watch?v=YPTeetaWZ3Q
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: 16 volts Alternator [Re: chryco] #568594
01/02/10 11:52 AM
01/02/10 11:52 AM
Denmark
Denmark
Chryco i love your dart
Re: 16 volts Alternator [Re: Dart of Denmark] #568595
01/02/10 01:15 PM
01/02/10 01:15 PM
Sweden
Tobbe Offline
Tobbe  Offline
Sweden
i have a little mitsu alternator whit a volt sensing cabel , itīs possible to fool the alternator to think the volt is low ,also have a trick for boost volt on older bosch whit internal regulator
what alternator do you run?
Re: 16 volts Alternator [Re: Tobbe] #568596
01/02/10 01:34 PM
01/02/10 01:34 PM
Denmark
Denmark
Nippondenso IR/IF 55
Re: 16 volts Alternator [Re: Dart of Denmark] #568597
01/02/10 04:47 PM
01/02/10 04:47 PM
Sweden
Tobbe Offline
Tobbe  Offline
Sweden
if it have a volt sensing cable you kan put a diod(“cut-in” voltage ) as a "resistant" to offset voltadjustemt
whats a Diod ?
cabel I in this pic
