Re: Just installed the new Unlawful frame conectors
[Re: StyleElements]
#568113
01/06/10 10:43 PM
01/06/10 10:43 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Man what did I say about this kit????
Didn't notice the tubing used for the frame connector is bent. Also didn't realize the plate for your roll cage is not part of the connector.
Here is something to think about. A straight peice of alluminum tubing. You can walk around and push ceiling tiles out of position and even slide boxes off the top shelf with it. Now take it and put the slightest bend in the tubing. Go back and try to do the things you tried before. You can't the bend just get's worse.
Tubing is bent all the time in race cars. But, if you notice there is a supporting structure welded in to support that bend.
Omg dude you totally called it
Yes, let's look at your analogy. Pushing ceiling tiles out of position takes almost no effort. Your piece of aluminum tubing with a slight bend in it is going to need to be paper thin for it to bend oppose to moving a ceiling tile. Assuming you're not using a paper thin aluminum pipe, the pipe even with a large bend in it will be much stronger than the force it takes to move the ceiling tile. This is exactely why your anology doesn't work. A 1.625 .120 wall pipe with a slight bend in it is a lot stronger than the sheet metal it's bolted to. The 1.625 .120 pipe will be the last thing to fail.
Nobody is talking abgout failure, we are talking good design practices, common thinking is any member that changes direction needs to be supported/braced/triangulated at the bend. If not, bending will be significantly easier, however slight. We should always be trying to achieve the greatest stiffness with the least/lightest design, anything else is a compromise. KISS Memo applies here I think,
His analogy was only a generalization for visualization purposes, wasn't likely meant to prove or disprove anything.
[Re: jcc]
#568118
01/07/10 01:30 PM
01/07/10 01:30 PM
Posts: 439 Ortonville, MI
StyleElements
Ortonville, MI
the "bend" fix is kinda easy.
There is no "bend fix". The pipe is bent so it doesn't have to go though the floor of the car. To have a bolt in frame connector that bolts to the factory spring hanger mount it is physically impossible not to have a bend in the pipe, and these have been designed to be as straight as possible. To claim there is a "fix" and it's "easy" is laughable
[Re: rapom]
#568120
01/07/10 02:17 PM
01/07/10 02:17 PM
StyleElements
Ortonville, MI
What kind of money does this kit run. I checked the website and couldn't find any info on it.
We haven't actually released them to the public yet. They were installed on Keith's car for test fitting, etc. I believe they decided on $429. They will be released on on our website in probably a week
[Re: JERICOGTX]
#568122
01/07/10 04:13 PM
01/07/10 04:13 PM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
$429 for sub-frame connectors and the drive shaft hoop kit. No they are not powder coated.
Jack Irons Jr.
'67 GTX, turbo 6.1 HEMI
[Re: StyleElements]
#568126
01/10/10 09:02 PM
01/10/10 09:02 PM
Posts: 4,209 New York
polyspheric
New York
The long tube (judging entirely from the appearance as pictured) has the OD of at least one end located outside the OD of the bend (in cross-section, the diameters don't even touch). With the same bend, the resistance to buckling in compression can be substantially increased by simply increasing the tube diameter so that center of one is inside the diameter of the other.
Boffin Emeritus
