Re: ELEC FUEL PUMP: Holley 12-125
[Re: farmington]
#567062
12/30/09 07:19 PM
12/30/09 07:19 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
this is a good idea because: you can run 12-15PSI up to the carb to ensure you have enough fuel delivered to the engine, then step it down right at the carb to the desired 7-9 PSI. I'm afraid that if you stepped the pressure down at the pump with the internal regulator on it, that you'll also be cutting back on fuel delivery.
**Photobucket sucks**
