Re: porting 915 big block head article
[Re: Don_440]
#566913
12/30/09 04:44 PM
12/30/09 04:44 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I'll be alert about them then although I will keep stock valves, but sure will be an interest reading
[Re: Don_440]
#566914
12/30/09 08:19 PM
12/30/09 08:19 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Nacho RT74 ,sorry ,i got these articles ,the articles i was looking for was earlier I think,back when steve dulich built a660 hp 440,used this motor for serveral articles,but reall him doing a bunch of test on these heads,mabe even putting 2.25 intake valve in them
I remember that article, pretty sure it was printed later than the 3 part porting articles. I think you are correct about the 2.25 valve. Think he made 666 hp with a tunnel ram. I've never seen it online.You might try PMing Dulcich and see if he can help you.
[Re: forphorty]
#566915
12/31/09 11:57 AM
12/31/09 11:57 AM
Posts: 15,487 Florida
scratchnfotraction
I have about 10-11 yrs of mopar muscle mags i may have the one you need,I will look for it I know I started around 98-99 with the mag and have every one to date
[Re: ademon]
#566917
12/31/09 12:57 PM
12/31/09 12:57 PM
scratchnfotraction
I checked on it,seems I have a oct,nov 98 issues and started in april 99 sorry,I tried but i have them from april 99 to date if you need any other write ups
[Re: Runnin74]
#566924
01/01/10 11:54 AM
01/01/10 11:54 AM
Posts: 8,145 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Found it! Its called "Going With the Flow" and is in two parts in the January and February 99 issues.
Actually it's a 3 part article (part 3 was covered in March 99 issue) also seen in the links provided above by NachoRT74.
I only compared part 3 to the 3rd link and it appears to be the same article as "Going with the flow" (although that title did not appear). I did not read it in it's entirety but scanned it enough to be sure the pics and text match up.
[Re: Runnin74]
#566927
01/11/10 11:45 PM
01/11/10 11:45 PM
NachoRT74
Valencia, España
and they are using 346s, not 915s
[Re: Bill MeLater]
#566929
01/12/10 02:02 AM
01/12/10 02:02 AM
Posts: 277 MN
Willie68coronet
MN
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
