bullet valve springs #565819
12/29/09 04:09 PM
12/29/09 04:09 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
shearching for valve springs for a solid roller cam. looking for a good quality spring, has anyone ever used the bullet springs?
Re: bullet valve springs [Re: mopar dave] #565820
12/29/09 05:08 PM
12/29/09 05:08 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I've had great luck with PSI available through Isky. Get a whole season with no pressure loss with .772 lift cam.
Re: bullet valve springs [Re: supercomp] #565821
12/29/09 05:14 PM
12/29/09 05:14 PM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
P.S.I's here also got them from Henry Boyko in Mich.
Re: bullet valve springs [Re: jb15] #565822
12/29/09 05:46 PM
12/29/09 05:46 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Here ya Go
There listed as a Isky Spring, they are a PSI pac style spring. I ran a set on a 557" Wedge with .800 gross lift turning 7000-7400 rpms for about 3 seasons, and they still tested great. The retainers are about $80-$100 cheaper than the equal Comp Cams too..Im getting ready to get another set for the Hemi which has a .780 lift cam... They need a 1.95+ installed height to work with your cam though.
They are a 1.625 spring though, which IMO is minimal for a roller spring.
Looky and under $300
http://www.summitracing.com/parts/ISK-DR1224/
Re: bullet valve springs [Re: Bob_Coomer] #565823
12/29/09 05:49 PM
12/29/09 05:49 PM
Mt Morris Michigan
Mt Morris Michigan
i'll have to look at psi's site. i don't know if bullets springs are pacoloy or not.
Re: bullet valve springs [Re: mopar dave] #565824
12/30/09 11:22 AM
12/30/09 11:22 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
PSI 1224 are $260 at Isky.
Re: bullet valve springs [Re: supercomp] #565825
12/30/09 12:15 PM
12/30/09 12:15 PM
Mt Morris Michigan
Mt Morris Michigan
some of the people i'v talked to about those PSI springs only got one season out of them. i'm now looking at the isky toolroom gold strip springs. thanks
Re: bullet valve springs [Re: mopar dave] #565826
12/30/09 12:45 PM
12/30/09 12:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good choice... All I run are the Isky tool room springs and I`ve never had a failure and they`re still within spec when removed/replaced.
Re: bullet valve springs [Re: Thumperdart] #565827
12/30/09 01:16 PM
12/30/09 01:16 PM
Mt Morris Michigan
Mt Morris Michigan
i'v heard the gold strips are the best out there.
does anyone know who's making bullet's springs?
