Dual 390 CFM carbs..... #565697
12/29/09 11:23 AM
12/29/09 11:23 AM
Fredericktown, PA 15333
maundmotorworks Offline OP
Stealth poster
Stealth poster
In the past I've seen guys run dual 390CFM Holleys on the street. Anybody here done it? What are they like and is there anything special I need to know about them. I am aware that running a single 4bbl may well be the best way to go, but this is more for looks than anything. And it's going in a Dodge truck.....
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Dual 390 CFM carbs..... [Re: maundmotorworks] #565698
12/29/09 12:22 PM
12/29/09 12:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What kind of motor would this be going on and what kind of intake? Does your intake have enough spacing between the carbs to fit the overhang of the holley bowls?
Re: Dual 390 CFM carbs..... [Re: DaytonaTurbo] #565699
12/29/09 12:29 PM
12/29/09 12:29 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have them on a weiand tunnel ram on my 360. They work great.
Re: Dual 390 CFM carbs..... [Re: DaytonaTurbo] #565700
12/29/09 12:29 PM
12/29/09 12:29 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I run them!
box stock except for the quick change springs and vacuum port that ties them together .
part 20-73
I have tested my setup against a single 4bbl dual plane intake and a holley 780 cfm vac secondary carb.
the tunnel ram runs :
60' - 1.74
1/4 - 12.56
mph - 108 - 106
the stock cast iron intake ran :
60'- 1.86
1/4 - 13.2
mph - 102
I get 14-16 mpg with 3.23's and 26" tall tires
the track times are with the 3.23's and 24.5" tall slicks.
It it all on a stock 360 - small valve heads and kb 107 pistons - mopar 474 lift cam and dynamic 9.5" converter on a 904
Re: Dual 390 CFM carbs..... [Re: DaytonaTurbo] #565701
12/29/09 07:17 PM
12/29/09 07:17 PM
Stealth poster
Stealth poster
Ok, here's the plan for the engine. 426 Street Wedge, stock compression. Lunati hydraulic cam #60301 256/262 adv. duration .454/.475" lift 112 centerline, 1000-5500RPM. Edelbrock STR crossram. All painted orange and valve covers decaled to look kinda like a Max Wedge, though obviously not to trained eyes like us here. Now I only have the bottom part of the manifold, so I will be making a top, so making it to clear the carb bowls isn't an issue. It's going in a '47 Power Wagon that has been fitted with 4.10 Dana 60s, a divorced NP205 transfer case, and I have the NV4500 5-speed OD trans sitting in wait. I will be using MSD ignition and electric fans. I already understand that I will have to make all my mounts to intall it, I'm in the process now and it's nothing over my head. I just thought that an engine like that would look cool and run good in this vehicle. But I never tried the dual 390s on anything I've owned in the past, hence the reason for this post. So far the reviews seem good, and obviously I welcome opinions from knowledgeable people who have used these things. But building a truck motor is often different than one for a car, as this truck is very heavy and will haul sometimes. If they work well in a car, what will they be like in my truck?
Re: Dual 390 CFM carbs..... [Re: maundmotorworks] #565702
12/29/09 07:48 PM
12/29/09 07:48 PM
My sentiments exactly. If they fit on an inline dual 4bbl intake without flow choking/height increasing adapter plates I'd be interested too. A pair of street stacks sticking up thru the hood has gotta be cool.
Re: Dual 390 CFM carbs..... [Re: maundmotorworks] #565703
12/29/09 07:49 PM
12/29/09 07:49 PM
Stealth poster
Stealth poster
What about dual 450s? There's a nice set on the bag going cheap....would they be better than 390s?
Re: Dual 390 CFM carbs..... [Re: DJVCuda] #565704
12/29/09 08:13 PM
12/29/09 08:13 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Nice tubing work! I wish I could make 90` bends like that, mine always go a little too 90`. I cheat with aluminum underneath, but that swagelock stainless always looks great. I have a little thin walled stuff left, might try something like that on a 650 speed demon.
Re: Dual 390 CFM carbs..... [Re: Nukechargerboy] #565705
12/29/09 09:43 PM
12/29/09 09:43 PM
Manitoba, Canada
Manitoba, Canada
I thought the STR intakes caused some tuning challenges that might not make them best for a truck? Also with those intakes don't you need a pressure valve to vent pressure from the intake in the event of a backfire? I seem to recall hearing some horror stories over the years of STR's blown open from this..?
Re: Dual 390 CFM carbs..... [Re: DaytonaTurbo] #565706
12/29/09 10:04 PM
12/29/09 10:04 PM
Saskatchewan, Canada
barracudabob Offline
Even a pair of 600's with vacuum secondaries would work good. I ran them on a stock 440 years ago, and with some fine tuning of the secondary springs, it was great!
Re: Dual 390 CFM carbs..... [Re: DaytonaTurbo] #565707
12/29/09 10:17 PM
12/29/09 10:17 PM
Stealth poster
Stealth poster
The biggest problem was fuel puddling in the low spots of the plenum. The problem is easily solved by welding a couple small plates over the depressions. The STR and even the original Max Wedge manifolds had that problem, that's why they kept blowing those manifolds up. I'm definitely going to fix mine before installation. I was just worried about having too much carb for a low-RPM machine....
Re: Dual 390 CFM carbs..... [Re: Nukechargerboy] #565708
12/30/09 08:04 AM
12/30/09 08:04 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Thanks - The imperial bender sure does help... I was on a construction job with some .034 wall and used the leftovers for my car - you gotta do that everyday or you get the bend the wrong way more then you'd like - at leasr in my case...lol
That stuff is great - you can remove it and reinstall it with ease and no chance of leaks.
Re: Dual 390 CFM carbs..... [Re: DJVCuda] #565709
01/02/10 08:45 PM
01/02/10 08:45 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej,i did a mock up on my str-15 inline 8bbl with two holley 4160(4367) and the holleys dont fit on that one,because the fuelbowls.i guess that was expected.as you said max-wedge style i suppose your going with the left-right configuration .LOVE IT as miss Paris says.please keep us updated on your progress.i would like to know how it runs,as im also going to try the str-15 on the street in the future.
Re: Dual 390 CFM carbs..... [Re: maundmotorworks] #565710
01/03/10 10:12 PM
01/03/10 10:12 PM
Canada
CrAzYMoPaRGuY Offline
Canada
My daily driver work truck had a tunnel ram and two center float Holley 450 cfm carbs, it ran awesome, started excellent during the winter, no drawbacks compared to a single four barrel IMO....
My truck was heavy, it was a 3/4 ClubCab with 1 ton suspension, had 4.10 gears, 29" tall tires, a 727 with a stock stall converter, and could spin the tires while pulling a car trailer with a 1937 Plymouth on it....
440, 9.1 to 1 compression, mild head work, 268 Comp Cam, headers, it was pretty mild IMO....
The intake was a Weiand 3x2bbl tunnel ram converted to 2 four barrels...
CrAzYMoPaRGuY
Re: Dual 390 CFM carbs..... [Re: CrAzYMoPaRGuY] #565711
06/22/10 03:11 PM
06/22/10 03:11 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej ba.so how is it going with this setup? any news
Re: Dual 390 CFM carbs..... [Re: cuda-sweden] #565712
06/22/10 03:22 PM
06/22/10 03:22 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I'd also be interested in why the choice of the 60301. I only know enough to be dangerous. I'd think you'd want a little more cam than that even on street truck. I would also think the 390s might be small.
I run a 440 with a 750 Holley and the Lunati 60303 cam and a Performer RPM. So it is an apples to oranges comparison but now I kind of wish I'd gotten the 850 carb. But then again, this comb runs well so I'm not about to go and foul it up.
