Master cyl.and Booster rebuilder ? #565300
12/28/09 10:07 PM
12/28/09 10:07 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Can anyone give me their good/horror stories about rebuilders,I'm looking to send my master cyl.and booster to White Post restos.or Brake Place???
Any thoughts
I'm really not trying to be a pain in the
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565301
12/28/09 10:19 PM
12/28/09 10:19 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I use Booster Dewey in Oregon.
Although I haven't had any luck with anyone from Oregon, Booster Dewey did me right and I'll send him another one day. He rebuilt one hemi bendix booster and tested another NOS hemi bendix booster before I sold it.
logan426
Re: Master cyl.and Booster rebuilder ? [Re: MLR426] #565302
12/28/09 10:23 PM
12/28/09 10:23 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Ive called them and they only do the booster,I need the booster and master cyl.done.I'd like to get them done at the same place so its matched.
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565303
12/28/09 10:37 PM
12/28/09 10:37 PM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Karps Brakes in CA did my MC, booster, calipers and brake cylinders. I had a caliper come back with the powder coat a little thin, and rust started to form a year later. They fixed it no questions asked, and i had expected a little more grief.
Hope this helps.
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565304
12/28/09 11:01 PM
12/28/09 11:01 PM
PNW
Beebuzzn Offline
Beebuzzn  Offline
PNW
I used White Post back in the mid 90's for my master cyl. and front disc on my 67 R/T. Very nice job, but it was very $$$$$$$$$$$$$
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565305
12/29/09 10:46 AM
12/29/09 10:46 AM
MD
floyd Offline
floyd  Offline
MD
I used White Post for a 70 E-body booster and m/c but I won't use them again. They turned the parts quickly and all appeared good but I had some follow-on questions about the m/c after the work was done when I learned that the aftermarket piston kits for those m/c's are problematic. I got a ton of attitude from the guys from White Post when I tried to find out if they used my original pistons, etc.. They got pretty condescending and wouldn't even entertain the notion that they could have made a mistake.
I ended up having to get the m/c done again and I used these guys with great results:
Brake & Equipment Warehouse
455 Harrison St NE
Minneapolis, MN 55413
612-767-2629 – I spoke with Brad
BTW - My m/c required a sleeve. White Post uses brass sleeves and Brake & Equipment uses stainless. I believe stainless is better.
I haven't used Booster Dewey, but I've heard a lot of good things about his work.
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565306
12/29/09 11:10 AM
12/29/09 11:10 AM
Arizona
az426john Offline
az426john  Offline
Arizona
I used Booster Dewey for my booster and White Post for Master Cylinder, Calipers and Wheel Cylinders. No problems with any of them. However, White Post is expensive.
Re: Master cyl.and Booster rebuilder ? [Re: floyd] #565307
12/29/09 11:13 AM
12/29/09 11:13 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
455 Harrison St NE
Booster Dewey is super guy who does a really nice job...
Re: Master cyl.and Booster rebuilder ? [Re: MLR426] #565308
12/29/09 11:15 AM
12/29/09 11:15 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
logan426
HEY now... You have to be careful who you call "Oregonians", as we have had alot of "transplants" from other states.. We try to ship them off but they seem to stay..
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565309
12/29/09 11:27 AM
12/29/09 11:27 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Use Booster Dewey in Oregon and Mpls Brake Warehouse for your MC. I have used both multiple times and have been very pleased and both are very reasonably priced for their services. No need to look elsewhere!!
Re: Master cyl.and Booster rebuilder ? [Re: hemi70se] #565310
12/29/09 12:25 PM
12/29/09 12:25 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I'm wondering why you feel you need to send both components to the same place? Booster Dewey is hands down the best for booster restoration and Brake and Equipment Warehouse is outstanding for brake cylinder restoration.
Brake and Equipment warehouse doesn't paint the master cylinders black, so when you get it back you will need to paint it, put some protective plugs in the outlets, use Rustoleum semi gloss black to paint the entire assembly, and after waiting a week for the paint to dry, you are all set! If you want to, you can bolt the master cylinder to the booster and paint the entire unit together. But as far as finding a "one stop shop" for both components, I think you are much better off sending the booster to dewey and the MC to brake and equipment.
Re: Master cyl.and Booster rebuilder ? [Re: Mastershake340] #565311
12/29/09 01:01 PM
12/29/09 01:01 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
OK that does sound like the best way to go,Thank You all for your input.
Re: Master cyl.and Booster rebuilder ? [Re: minivan] #565312
12/29/09 05:19 PM
12/29/09 05:19 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
logan426
Hey Hey Hey Rick I didn't call anyone an Oregonian, is that a bad word ??. That's funny I'm glad someone was paying attention. Myself I've had crappy luck with people from Oregon for some reason. It started with Gordon FUNK......
Your an exception though.
logan426
Re: Master cyl.and Booster rebuilder ? [Re: Mastershake340] #565313
12/29/09 11:56 PM
12/29/09 11:56 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
What's your thought about the cover paint,I've painted them and the first time you remove the cover the bail scrathes the paint.
Sorry about these I think it's there funny!!
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565314
12/30/09 12:13 AM
12/30/09 12:13 AM
Crook County, ILL
Crook County, ILL
It all depends on if you are aiming for your car to OE correct. If you want to be accurate, you need to paint the assembly including the cap and bale wire. If you don't mind deviating a little bit, you can put a plated cap on it.
I've found if you are really careful, and use a couple screwdrivers, you can get the bale wire off the cap without scraping the paint. And if you scrape it slightly it is easy to touch it up with some black paint after you put the cap back on.
The other problem I've had, is brake fluid getting on the paint and lifting it. Not a problem if you use DOT 5, but with DOT 3 or 4 it is.
Re: Master cyl.and Booster rebuilder ? [Re: Mastershake340] #565315
12/30/09 01:07 AM
12/30/09 01:07 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Hey Master I tried to PM you but it's too full, Man you're popular !!!
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565316
12/30/09 01:22 AM
12/30/09 01:22 AM
Crook County, ILL
Crook County, ILL
Not especially popular , they reduced the PM limit considerably recently. I started deleting old PMs but still have a long way to go to clean out my inbox.
So I added my email address to my profile and figured people can contact me that way instead!
Re: Master cyl.and Booster rebuilder ? [Re: Mastershake340] #565317
12/30/09 08:44 AM
12/30/09 08:44 AM
Long Island NY
yellow sixpack Offline
Long Island NY
Brake and Equip wharehouse hands down the best. Sent alot of brake parts to them hands down the best. Great service pricing and shipping. Tons of knowledge and customer service.
If you can't be smart.....don't be stupid!
Re: Master cyl.and Booster rebuilder ? [Re: Mastershake340] #565318
12/30/09 02:10 PM
12/30/09 02:10 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Brad check your email address,I keep getting a error message.
Re: Master cyl.and Booster rebuilder ? [Re: Hemiruss] #565319
12/30/09 03:27 PM
12/30/09 03:27 PM
Crook County, ILL
Crook County, ILL
I assume you replaced the "at" with a @ and the "dot" with a . ? e.g @comcast.net
At any rate, I just sent you an email at the address you have listed in your profile.
