Wrinkle paint for air cleaner #564343
12/27/09 10:30 PM
12/27/09 10:30 PM
Rome, PA
Ryan_340 Offline OP
Ryan_340  Offline OP
Rome, PA
I am going to be restoring my '71 340 air cleaner for my Duster. Who makes the best wrinkle paint? And what are some tips and tricks to ensure it turns out nice.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564344
12/27/09 10:37 PM
12/27/09 10:37 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I used Krylon wrinkle finish on my last one.
I sprayed mine when it was over 90 outside and then took a hair dryer to it after each of the two coats.
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564345
12/27/09 11:43 PM
12/27/09 11:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually use the Dupli-color, reqires 3 full coats, 10 min between each, holds up to engine heat very well, use a heat gun and heat the inside/underside of the pc being sprayed wrinkle, applying a uniform heat, allow to dry for a few days
Re: Wrinkle paint for air cleaner [Re: Neil] #564346
12/27/09 11:51 PM
12/27/09 11:51 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
For me, VHT was easier to use than Krylon when I painted my hemi valve covers. For the VHT paint it didn't really make a difference if it was 60 degrees or 90 degrees outside. It was easier to paint when it was cold because the layers dried slower. Also the wrinkle was coarser when it was cold. When you spraying the paint you want the layers to be as thick as possible without it running. Apply the next coat when you start to see wrinkles starting to form. 3-4 thick coats of paint works well. You can do it with more thin layers of paint, but the idea is to get it thick before it dries. Another tip is shake the can a couple of minutes before each coat.
Re: Wrinkle paint for air cleaner [Re: DAYCLONA] #564347
12/28/09 12:06 AM
12/28/09 12:06 AM
British Columbia
plumcrazy101 Offline
British Columbia
Tried various brands of wrinkle paint but the brand I have had the most success with is VHT.
Prepare the surface by bead blasting and use the method that Dayclona suggested.
Couple of suggestions would be to insure the shop is warm and if an oven is available use that to cure the paint.
Re: Wrinkle paint for air cleaner [Re: plumcrazy101] #564348
12/28/09 12:11 AM
12/28/09 12:11 AM
Rome, PA
Ryan_340 Offline OP
Ryan_340  Offline OP
Rome, PA
I was planning on bead blasting, do I need to use primer before the wrinkle paint?
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564349
12/28/09 01:09 AM
12/28/09 01:09 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
I had mine powdercoated and love how it came out, durable and great texture and color.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Wrinkle paint for air cleaner [Re: 340wedge] #564350
12/28/09 07:34 AM
12/28/09 07:34 AM
Alabama
BigMoneyLewis Offline
Alabama
Wrinkle paint can be hard to work with. The best tip I can give you is ...Heat . Preheat your oven to 200 degrees. After applying 3 medium to heavy coats , approx 5-10 minutes apart, place your air cleaner in the oven . Ten minutes should do it .
I restored a '69 Camaro underdash 8-track player 2 weeks ago, and the housing on those units is black wrinkle. It came out fantastic . I have sprayed probably a dozen air cleaners in the past , with
so so results , but this was my first time putting something in the oven . It came out great, and was fully dry when it came out, and wrinkled very evenly all over . I highly recomend the oven .
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios
We can restore YOUR radio usually in less than 30 days
Visit our NEW website..
http://www.wardsclassiccarradiorepair.com
gregward@mchsi.com
phone 256-852-0955
gregward@mchsi.com phone 256-852-0955
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564351
12/28/09 12:10 PM
12/28/09 12:10 PM
British Columbia
British Columbia
No primer required with VHT wrinkle paint. Just prepare the surface by bead blasting (insure all rust is removed) and a wipe down of lacquer thiner to remove any dust or oil before spraying.
Instructions from a can of VHT that was in the shop include
Do not spray at temperatures below 70 degrees
For best results spray a heavy coat followed by 2 or 3
additional thiner coats 2 minutes apart.
Size of the wrinkle will depend on the thickness of the
paint.
Hold the can 8 to 10 inches from the work.
Curing of paint to wrinkle finish will take 20 minutes to
12 hours after final application.
This process may be accerated by a heat lamp or hair dryer.
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564352
12/28/09 01:32 PM
12/28/09 01:32 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i've done a few of these with different paints.
it's not too difficult,just follow the directions and give 3 good coats about 5 - 10 minutes apart on a warm day.
warm with a hair dryer or place it in the sun to speed up the wrinkling,and a small run or two will make it more realistic...but most of us don't want it that correct.
Re: Wrinkle paint for air cleaner [Re: can.al] #564353
12/28/09 02:18 PM
12/28/09 02:18 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I used the Harley Davidson Wrinkle Black and a BBQ grille, came out great and looks like the valve covers just came out of the factory.
Re: Wrinkle paint for air cleaner [Re: 340wedge] #564354
01/03/10 07:18 PM
01/03/10 07:18 PM
MS,USA
mohotrodder Offline
mohotrodder  Offline
MS,USA
Do you know the mfg and code of the powdercoat that was used?
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564355
01/03/10 07:23 PM
01/03/10 07:23 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I have used Eastwoods twice and was satisfied with the results. All the other advise you have see nis correct. Cleanliness and heat are key to success.
Re: Wrinkle paint for air cleaner [Re: 340wedge] #564356
01/03/10 11:40 PM
01/03/10 11:40 PM
SeventySatellite Offline
Show some pics.
Re: Wrinkle paint for air cleaner [Re: SeventySatellite] #564357
01/04/10 01:26 AM
01/04/10 01:26 AM
340wedge Offline
340wedge  Offline
I'll have to resize the engine pics i have, here's a bad cell phone pic from a distance
Re: Wrinkle paint for air cleaner [Re: Ryan_340] #564358
01/04/10 10:26 PM
01/04/10 10:26 PM
340wedge Offline
340wedge  Offline
Here's a few pics of the air cleaner
Re: Wrinkle paint for air cleaner [Re: 340wedge] #564359
01/04/10 10:27 PM
01/04/10 10:27 PM
340wedge Offline
340wedge  Offline
One more..................
Re: Wrinkle paint for air cleaner [Re: 340wedge] #564360
01/05/10 02:55 PM
01/05/10 02:55 PM
That looks good. I've been thinking about doing that when the time comes.
