Bolting Trans to aluminum block
#564041
12/27/09 02:40 PM
12/27/09 02:40 PM
Posts: 6,295 U.S.
moparniac
U.S.
how many ft lbs torque or do you guys just run studs. thx
Mopar Performance
Re: Bolting Trans to aluminum block
[Re: moparniac]
#564042
12/27/09 02:41 PM
12/27/09 02:41 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
I use studs and frankly we use the impact to put them(the nuts)on with Of course it is juts a little 3/8" one.
[Re: moparniac]
#564044
12/27/09 02:56 PM
12/27/09 02:56 PM
I use studs and franly we use the impact to put them on with Of course it is juts a little 3/8" one.
you wouldnt happen to know how long from the block out my 727 is in the shop! BTW this is the last time I ever pay for a 727 build as Im gonna do it myself from here on out! everyone says how easy it is....
im thinking the same size as the starter motor stud,going to check it out now, think i like the course thred in block to fine thread.
[Re: moparniac]
#564045
12/27/09 02:57 PM
12/27/09 02:57 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I hav1n`t actually checked the torque on mine (K/B block - 'Glide ). I would assume it to be 45 - 50 ft lbs. The belhousing and the block are both ally , so the expansion rates will be similar . Chryco
P.S. I only use stainless fasteners going into aluminum ,a little Neverseize doesn`t hurt either.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#564046
12/27/09 03:25 PM
12/27/09 03:25 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
The 3/8 bolts I would torque 35-40 and on the 7/16 I would torque to 50. Definitely use neverseize if the threads are aluminum. I would not run studs unless you have a removable trans tunnel. I would think it would be a pain in the butt with a shield,studs and stock tunnel to pull the trans out,since you are going to build it yourself just my
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: moparniac]
#564048
12/27/09 04:19 PM
12/27/09 04:19 PM
67HEMI
If they are 3/8 like an iron block,35 to 40.The lower 2 that screw into the trans plus the starter are 7/16 and I would torque them to 50.
