Head gaskets for high compression RB #563658
12/27/09 12:35 AM
12/27/09 12:35 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
What head gaskets should I be using with a cast iron 440 block and aluminum heads with over 13.5 to 1 compression ratio?
Thanks, Brian
Re: Head gaskets for high compression RB [Re: '72CudaRacer] #563659
12/27/09 12:46 AM
12/27/09 12:46 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Cometic for me
Re: Head gaskets for high compression RB [Re: Bob_Coomer] #563660
12/27/09 10:02 AM
12/27/09 10:02 AM
NC
440Jim Offline
440Jim  Offline
NC
I am right at 13.5 and have been using the Cometic head gaskets since 2006 with no problems. I coat mine with spray copper coat for head gaskets.
Re: Head gaskets for high compression RB [Re: 440Jim] #563661
12/27/09 10:13 AM
12/27/09 10:13 AM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
x 3
Re: Head gaskets for high compression RB [Re: Youngblood] #563662
12/27/09 12:47 PM
12/27/09 12:47 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Where's a good place to get the Cometic gaskets - looks like they run $99 per at Summit.
Re: Head gaskets for high compression RB [Re: 69dart] #563663
12/27/09 01:09 PM
12/27/09 01:09 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I take out the rivets and spray both sides of all three with copper coat. No leaks.
Re: Head gaskets for high compression RB [Re: supercomp] #563664
12/27/09 01:55 PM
12/27/09 01:55 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
My new mill has cometics as well. However I read in a recent post that the mls Mr Gasket gaskets appear to be exactly the same as the cometics and it was suggested that they were in fact made by cometic but were priced around $20 a piece less. May be worth looking into
76 Duster work in progress
Re: Head gaskets for high compression RB [Re: Edge] #563665
12/27/09 02:50 PM
12/27/09 02:50 PM
I made that post, the Mr Gasket MLS nitril coated gaskets are Cometics I used the 4.410 bore size and the .041 thick gaskets. 1969dart, you do need to make sure that the finish on the block deck surfaces and the head surfaces are a 10 RA or smoother If not they may leak water around the water ports and out of the motor Been there done that on the first set of Cometics I used on a 426 Hemi motor several years ago BTW, the instructions with the gaskets say to not use any coatings on them, put them on dry, I did Maybe after using them once you might want to spray them with something They are three layers of stainless steel gaskets rivited together
Re: Head gaskets for high compression RB [Re: Cab_Burge] #563666
12/27/09 05:15 PM
12/27/09 05:15 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks guys,
Looks like its going to be a MLS gasket. I did not realize that they were reusable. How many times can they be reused?
The RA10 finnish on the deck... just tell machine shop? How do I tell what finnish I've got? What about alum heads, same finnish?
Also head bolts or studs?
Thanks, Brian
Re: Head gaskets for high compression RB [Re: '72CudaRacer] #563667
12/27/09 05:45 PM
12/27/09 05:45 PM
detroit area
moderncylinder Offline
detroit area
ive reuse my cometics about 6-7 times,, spraying them with copper coat each time... i keep using them till they look like they are falling apart or cracking in the fire ring area
