Tail light bezel stud after chroming, ideas? 70 Bee
#563398
12/26/09 09:12 PM
12/26/09 09:12 PM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
Had the tail light bezels rechromed for my 70 Bee, they turned out great, but have issues with studs. Some are worse than this picture, but there isn't much "meat" left on them to use the original style pal nuts. The nuts may work fine in areas of the stud, but some places the stud is so deteriorated they will just spin. I don't want to step down a size as I am sure they will snap off. I had this one clip laying around that would work great, but it is a little too big. Any idea where I can get this style of clip, but smaller, or other ideas? This clip is squeezed, slid into place and is spring loaded, this won't twist the studs off. ![](http://i101.photobucket.com/albums/m75/psrde/Super%20Bee/Superbeetaillight002.jpg)
Re: Tail light bezel stud after chroming, ideas? 70 Bee
[Re: N9671X2]
#563399
12/26/09 09:34 PM
12/26/09 09:34 PM
340dart4spd
Parts Problem
Parts Problem
take a blunt punch..flatten the inside of nut a little..
[Re: gtx6970]
#563404
12/27/09 10:45 AM
12/27/09 10:45 AM
N9671X2
Grand Rapids MI
6 studs per bezel, and no, they are not machine thread, they are threadless and rely on the pal nut cutting in to the smooth post. That idea works OK when originally installed, but after on and off a few times, and rechroming, not so well !! The other issue is the bezel is the only thing that secures the actual tail light housing to the rear panel of the car, so it needs to be held pretty tight. If it were just the bezel, like mentioned above the pal nuts with the sealer in them would probably hold the bezel a lone fine. I did pick up some these, which I will probably hav to end up using. I was hesitant about using them though as once they are on, removing them in the future would be a major pain. That being said, doubt they would ever have to come out again. http://www.aaronspushnuts.com/tinnerman_spring_nuts.htm
[Re: 1_WILD_RT]
#563407
12/27/09 02:08 PM
12/27/09 02:08 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
Paul - A thin coat of JB weld or 2 part epoxy may work just fine. You could put it on with a small brush. Once it hardens your acorn nuts should work just fine.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
