Re: 3.23 and 727 speedo gear
[Re: IMGTX]
#563235
12/26/09 05:18 PM
12/26/09 05:18 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Clocking is easy.
It isn't very clear in that pic but under the arrow at the 6'oclock position there is a dot cast into the extension housing. That dot roughly lines up with the numbers that represent your gear.
i.e. if you have a #30 gear line the numbers 26-31 on the adapter to the dot.
Install the clamp with the tabs in the slots and your done.
I agree it is easy... But not knowing about it would be bad...
[Re: roy2345]
#563236
12/26/09 05:20 PM
12/26/09 05:20 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
MOP...=item414ba7e5c1 is what i ordered. Is this clocking device already on the tranny?
care to clarify...
[Re: roy2345]
#563241
12/26/09 08:01 PM
12/26/09 08:01 PM
RapidRobert
I'd put a piece of flat stock on top of one of your rear tires and measure from the underside of it to ground for your exact diameter. With that # and your gear ratio (3.23) the simple chart in the archives worked for me dead on. Made my odo correct measured by the interstate mile markers and also my speedo correct measured at a roadside digital mph sign.
[Re: 1_WILD_RT]
#563245
12/26/09 11:10 PM
12/26/09 11:10 PM
Posts: 12,235 Looking for a way out of Middl...
IMGTX
Clocking is easy.
Your right. I though I was helping but you are a much faster typer....
[Re: roy2345]
#563246
12/26/09 11:14 PM
12/26/09 11:14 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
sorry guys.....the tire size is 225 55 17....so what gear would that be?
26.8 = 32 teeth
