Carb for 500 Mopar Performance stroker motor? #563155
12/26/09 01:34 PM
12/26/09 01:34 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
I was able to get a deal on a 500 stroker Motor from MP, I need a carb they say a 850cfm works best, Which one would you use? Its goin in a 1968 Satellite weighs 3800 with me in it. I have a 4500 stall or I can use a 2400 stall converter, its 509 lift 248 duration 9.1 compression, so anyway which 850 carb? Holley Proform BG?
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563156
12/26/09 01:44 PM
12/26/09 01:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I was able to get a deal on a 500 stroker Motor from MP...
Save your carb $$$ and tear that thing down first to verify it was machined and assembled correctly. Some of those things turned out to be real POS, so my level of confidence w/ just bolting one in is basically zero.
Re: Carb for 500 Mopar Performance stroker motor? [Re: BradH] #563157
12/26/09 01:57 PM
12/26/09 01:57 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yes
I always hear horror stories on those engines, super tight oil clearances, super tight valve guides.
I recommend a 950 CFM carb, if your on a budget, get a Quick Fuel or Pro Form 950.
Re: Carb for 500 Mopar Performance stroker motor? [Re: Bob_Coomer] #563158
12/26/09 02:09 PM
12/26/09 02:09 PM
UK
602heavy Offline
602heavy  Offline
UK
What heads are on this thing? , 9.1 CR sucks with alu heads , burn speed is too slow which will cause sooting @ low speed , idle/transition circuit will be a mare to tune , spark lead could be anywhere between 40*/50* .
Re: Carb for 500 Mopar Performance stroker motor? [Re: 602heavy] #563159
12/26/09 03:23 PM
12/26/09 03:23 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I don't know who assembles the wedge crates, but I can tell you from experience with a Cummins built Hemi crate that Stevie Wonder, working in a barnyard, could do better work! Like Brad said, tear it dowm and check everything! That said, the Holley HP950 is one of the best performing, out of the box street carbs for these strokers. I have used several and been very pleased with the results.
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563160
12/26/09 03:24 PM
12/26/09 03:24 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
The heads are High Flow iron Stage V heads 2.14 intake 1.81 exhaust. Well has anyone ever actually had terrible luck with one of these crate motors, True experiences. Thanks for all the advice
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563161
12/26/09 03:47 PM
12/26/09 03:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I recommend you tear it down also because MP has not sold that engine since at least 2004. So if it's advertised as "brand new"...that point is somewhat debatable. If it's an "engineering dyno mule" consider the use/abuse it might have seen and take that into account too. Either way Look for rust/moisture/storage damage/dry areas that shouldn't be, just because it's old and has probably been sitting.
Not only that but the warranty is based on time only, 90 days (not use) and is long expired...so yeah, go through it.
Carb wise MP always recommended an 850 vacuum, but if it were mine I'd want to try an 850 annular dp.
There are a couple 500 wedge cars floating around here, hopefully the owners will post some real experiences.
Rich H.
Esse Quam Videri
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563162
12/26/09 03:56 PM
12/26/09 03:56 PM
AndyF Offline
AndyF  Offline
The carb depends somewhat on how you're going to use the motor. For bracket racing duty I'd probably go with a Holley 1000HP which is basically just the old 850 DP carb with a profiled air horn. (no choke housing). Those are nice carbs and they'll work well with 500 inches.
Re: Carb for 500 Mopar Performance stroker motor? [Re: AndyF] #563163
12/26/09 04:02 PM
12/26/09 04:02 PM
AndyF Offline
AndyF  Offline
For street use I'd go with a smaller venturi than what the 850 DP carbs had. With 9:1 compression and a 509 cam a small venturi carb would probably help the driveability a bunch. If it was my car I'd start with something like this BLP modified 650 Holley. I know that everyone will tell you that a 650 is way too small for a 500 inch motor but I bet if you tried a carb like this it would work a ton better than a 850 DP.
You have a heavy car with low compression and a camshaft with a bunch of overlap. Unless you have some 4.86 rear gears you'll probably be better off smaller rather than larger in the carb department.
Re: Carb for 500 Mopar Performance stroker motor? [Re: AndyF] #563164
12/26/09 04:09 PM
12/26/09 04:09 PM
UK
602heavy Offline
602heavy  Offline
UK
Can't find the cam specs posted on this motor.
Re: Carb for 500 Mopar Performance stroker motor? [Re: 602heavy] #563165
12/26/09 04:15 PM
12/26/09 04:15 PM
AndyF Offline
AndyF  Offline
Crate motors used the 509 hyd cam which is an okay cam if you know how to tune around it. It has a bunch of overlap though which makes it a pain when combined with low compression and a 1.560 carb. That was the standard "street racer" combo back in the 70's and a lot of those cars ran like poo.
If the guy knew how to clean up the idle circuit it would work okay but not a lot of people knew how to do that 30 years ago. (no billet metering blocks back then) The other crutch would be 4.88 rear gear and/or a bunch of initial advance.
Re: Carb for 500 Mopar Performance stroker motor? [Re: AndyF] #563166
12/26/09 04:19 PM
12/26/09 04:19 PM
UK
602heavy Offline
602heavy  Offline
UK
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563167
12/26/09 04:20 PM
12/26/09 04:20 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Cam specs are 248 duration @ 0.50 509 lift
I am going to bracket race the car with this motor, no or very little street. Oh and the gears are 3.91
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563168
12/26/09 04:25 PM
12/26/09 04:25 PM
UK
602heavy Offline
602heavy  Offline
UK
What's the lobe sep? , only asking for refference as don't want another debate.
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563169
12/26/09 04:27 PM
12/26/09 04:27 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
This is what I was looking at:
Proform race series 850 DP
Description:
Finally an affordable high-performance race carburetor! PROFORM's new Race Series Carburetor is hand assembled in the U.S. utilizing the PROFORM High-Flow Carburetor Main Body, durable billet metering blocks, and a high performance billet throttle base plate.
The PROFORM Race Series Carb includes:
PROFORM Carburetor Main Body High-Flow Main Body!
Dyno-Proven Horsepower & Torque Gain!
Adjustable, Screw-In Air Bleeds!
High-Performance Down-Leg Boosters! (except 650 CFM)
Maximum Air Flow.
No Air Horn, Choke Tower, or Choke Control!
High-Rate Air-Flow Section Design!
PROFORM Billet Throttle Base Plates
Adjustable Secondary Air Flow Cam Bracket!
Solid Billet Construction!
Hand-assembled in the U.S.!
Timed & Full Vacuum Tubes for Accessories & Tuning!
Welded Throttle Shaft!
Button Torx Head Throttle Plate Screws!
Power Valve Blow Out Protection!
Slip Link Mechanical Secondary Linkage!
PROFORM Billet Metering Blocks Solid Billet Construction!
Durable, No Warping or Porosity Problems!
Changeable Idle Feed Restriction
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563170
12/26/09 04:28 PM
12/26/09 04:28 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Don't know the lope sep.
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563171
12/26/09 04:30 PM
12/26/09 04:30 PM
tboomer Offline
tboomer  Offline
Get a hold of Jesse from Bigs on the board here...He can fix ya up!! Just ask Davey Boyd...
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563172
12/26/09 04:32 PM
12/26/09 04:32 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Lobe sep= 108 deg.
cam card info here http://victorylibrary.com/mopar/mpcam-tech-c.htm
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: Carb for 500 Mopar Performance stroker motor? [Re: 1AARCUDA] #563173
12/26/09 05:34 PM
12/26/09 05:34 PM
AndyF Offline
AndyF  Offline
The ProForm 850 DP is probably a 1.560 carb which I think is too big for your combination. Once again, heavy car, low compression, lots of overlap and moderate rear gears. I'd go smaller, probably nothing bigger than a 1.375.
Re: Carb for 500 Mopar Performance stroker motor? [Re: AndyF] #563174
12/26/09 05:53 PM
12/26/09 05:53 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Hello....the best choice for this application is the Holley 950HP in my opinion....
The 950 has the smaller 1.375 venturi that your gonna need to get this heavy car up and moving off the starting line....The Proform 850 & Proform 950 carbs both are larger on the venturi diameter at 1.400 & 1.450....and that is starting to hurt your bottom end responce as you go bigger then the 1.375....
whether you buy a Holley HP or have a custom carb built, you will be happy....
I attatched a link to our BIGS Stage 5 950 below....we have great pricing left over from the Holidays also.....Thanx allot, Jesse @ BIGS!!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200421128946&ssPageName=STRK:MESELX:IT
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
