4 speed part 2 adj. pressure plate/clutch
#563072
12/26/09 10:00 AM
12/26/09 10:00 AM
Posts: 521 somewhereintheswampsofjersey
1swingin
O.k. Iam going 4 speed against my stock eliminator buddys wishes. Its mainly gonna be a street car so it makes sense. Question two. He runs a jerico with an adjustble pressure plate so he can control how hard the clutch hits. He highly recomended i use one. Where do i get one,what brand should i use,and how much do they cost? He said i can eather buy an adj. or change the springs and shim a stock one. That sounds like a pain in the but. I have experiance with adj. plates on heavy equipment/dump trucks/cranes/etc. and he showed me his. Is this overkill for a street/strip car? I will spend the money i just wanna make sure its worth it! Thanks again guys. You have been very helpful.
"I aint here on buisness baby,Iam only here for fun"
Re: 4 speed part 2 adj. pressure plate/clutch
[Re: 5126brl No more]
#563074
12/26/09 10:51 AM
12/26/09 10:51 AM
Posts: 904 cleveland Ohio
mloboda
cleveland Ohio
Johnny, Before you buy any clutch setup,give Tim Hyatt a call 440-254-1311. He is a great guy and will explain exactly why you need what you need. Very reasonable prices as well. He probably does 40% of the clutches for UMTR racers and has been doing this for 30+ years. www.umtrnorth.com chat forums are a great source of info as well. Go to the "clutch tech" and "tranny tech" sections of the forum
[Re: mloboda]
#563075
12/26/09 12:20 PM
12/26/09 12:20 PM
1swingin
Thanks guys! I had no idea there was a tranny tech on moparts! My stocker buddy wants me to get a mcleod long style adj. pressure plate. 11in. prefered but a 10.5 will work. He also said they are super expensive!!!! Anyone know of an alternative adj. that may be a little cheeper?
[Re: 1swingin]
#563077
12/26/09 12:37 PM
12/26/09 12:37 PM
1swingin
Your buddy is the man! Hes got an adj. modular steel plate he builds himself for 500 bucks! as aposed to a mcleod that goes for 1k! thanks alot guys!
[Re: Moparteacher]
#563079
12/26/09 01:02 PM
12/26/09 01:02 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
The least expensive "do-it-yourself" route would be RAM clutches. $700-$1,000 for disk and PP.
![](/ubbthreads/images/graemlins/thumbs.gif)
If you do go the Ram way get a Adjustable that you can add weight to in the arms. I wish I did. There is better choices but they get $$$$ . I make about 590 hp at the flywheel and do a fair amount of street driving so I am pretty happy with the ram. All told with the flywheel disc and plate I still spent around $800. Good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 1swingin]
#563081
12/26/09 06:47 PM
12/26/09 06:47 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
I just put a reply on your other thread suggesting Tim. He is the man ![](/ubbthreads/images/graemlins/thumbs.gif)
Mike
